AnalogSteph
I think you'll want to correct your typo there... Any UK-based readers are probably dying with laughter.I can even wee on the plot when the display is ON and the difference between power brick. Great success!
try to increase the ADC input level up to .1-.5db to find the lost 3dbI get a THD+N of almost -111dB and this is only 3 dB shy of what Amir had. This is great!
Yes, I will try to modify the ADC input range.try to increase the ADC input level up to .1-.5db to find the lost 3db![]()
Just a little calculator with E1DA boxYes, I will try to modify the ADC input range.
Hi IvanFrenchFan, 2pA/Hz^.5 is the current noise of OPA1612, which needs to be included in the account.
~ 1.8 KHz cutoff?? 2 KHz?BTW, I am trying some LPF proto, standalone one, with a switchable gain 2.5db/7db or 4.65V/8V with 9039S as an input DAC. That possible to use with AP as well, for instance, my old 2522 gen has THD+N 124.5db@1k after the LPF. Actually, the results below are limited rather by APU than LPF.
So this is proto of the Ultra-low THD 1kHz Sine Wave Generator?BTW, I am trying some LPF proto, standalone one, with a switchable gain 2.5db/7db or 4.65V/8V with 9039S as an input DAC. That possible to use with AP as well, for instance, my old 2522 gen has THD+N 124.5db@1k after the LPF. Actually, the results below are limited rather by APU than LPF.
Is the USB connection for power?nop, it is the Low Pass Ffilter.
Looks very promising. This unit, combined with a high performance DAC, is the absolute best competitor to the high performance AP analog signal generator, except in single frequency mode (note: the most useful). It's time to complete the project and bring to market a 1 kHz active LPF device for measurements.right. A bit cleaner sine is achieved today(Tweak_9039 is used):
