did you buy that in E1DA Aliexpress shop? The rear panel of ADC has the M2 thread(I measured that with a caliper from the inner side 1.71mm) suitable for the cable's screw(the caliper shows 1.93mm). If you can not measure these diameters, please show me pics of how the screw floats in the panel, I want to realize why it happened, and what I should send you a new panel or a new cable.Does anyone has the USB cable with screw for ADCiso? I bought one but it looks like the hole in the case is too big and the screw just passes through.
Yes, both the ADCiso and the cable were ordered there about 2 weeks ago. Here's the sticker from the package of the cable:did you buy that in E1DA Aliexpress shop?
I only have a manual caliper (admittedly not in its prime). To my eyes (also not in their prime):If you can not measure these diameters, please show me pics of how the screw floats in the panel
My local kind-of Home Depot has only M3 and bigger. I could order online but the delivery costs for the ones I've found are about the same as the price of a new cable. So I ordered the Delock mentioned above. There's slight chance it will be here tomorrow, if not then next week.Can you try any standard M2 screw with the panel?
I got 84028 but similar results.So I ordered the Delock mentioned above.
There are 2 reasons:
1) each Cosmos ADC is calibrated i.e. H/H3 harmonics are minimized individually.
2) ESS used APx555 gen to test that chip, 555 is known as a too noisy analyzer to measure modern DAC/ADC.
BTW, Cirrus Logic offered some LNA circuit to test with APx555 and get the specified noise level for CS43131/43198 $3 DACs.
That's insane... I guess that is using the same technique for THD calibration as used in the ADC?no, Victor's OSC(good for THD but be aware that the OSC's H3 is rising quickly from >4V), is even noisier and bad for THD+N. The option with less noise vs APx555 is my new THD stellar 9039S, some samples have THD -145-149db i.e. all harmonics are surely lower than -150db@1kHz. 10kHz H3 -135db is also perfect. The golden sinegen would be a decent DAC+LPF tuned at 1000Hz to cut all harmonics and noise.
Balanced version takes negative signal from pin 7 of opa (see pic) - todays version use OPA1656 and 100 Ohm output resistance."no, Victor's OSC(good for THD but be aware that the OSC's H3 is rising quickly from >4V)"
what V ? only Vpp applies to 4
Output voltage without load 300mV - 2.7V (RMS)
Got the new panel and locking fits well now. Thank you.if the problem is the panel, please contact Sunny from our Aliexpress and she'll send you a new panel.
as I remember I have deleted 705k mode in one of earlier FW, and it is not supported. Next 3 days I'll back home and check that again.Did anybody encounter problem with Cosmos ADCiso at a sampling rate of 705.6kHz? No problems have been found at other sampling rates including 384kHz and 768kHz. Comtrue ASIO driver was used.
Sampling rate: 384kHz
Sampling rate: 705.6kHz
Sampling rate: 768kHz
