johny_2000
Thank you! I'll check/compare this with your screenshot of the driver name/version when I get back to my workstation. Maybe tomorrow.Cosmos ADC works without Comtrue driver, if you need to install the Comtrue driver you probably want to reflash some FW. I don't know.
Simply put, I don't care whether I work with or without a Comtrue driver, as long as it works properly.
Now (without the ComTru driver) I am having difficulty switching the device to Stereo mode from the default Mono mode using the Windows volume slider.
REW has two modes of working with the device - Direct or Exclusive mode. I've tried both options. In an Exclusive mode, the device remains in Mono mode (and I need Stereo for measurements), except when I launch the Tweak app and manually move the slider to the 2CH position (maximum to the left). In direct mode, I tried to change the volume manually, and at first glance, switching to Stereo mode occurs at volume values less than 18, but the output data from the ADC is somehow strange. The noise level is elevated (approximately -40-45 dB floor), and the measured signal values are +2...+3 dB from the actual one.
