E1DA Cosmos ADC
Also in tweak app what does read and connect tab does? I got 0 and -10 while selecting adc1, 2,3,4. I did not change any values in the app. I only used read and connect app.
Skj, I'm not familiar with apps you using but did you read about Cosmos ADC stereo/mono mode switching? https://e1dashz.wixsite.com/index/cosmos-adc
Thanks. If we use tweak app to switch to stereo and unplug the adc, does it remain in stereo mode or every time it needs to be swiched to stereo mode in tweak app? I think I am using the adc while "it is not in stereo mode" because of that channel 1 is recording L+R and channel 2 is recording R so getting lopsided recordings. May be if I set it in stereo mode I get correct recording. But the question if it will remain in stereo mode after unplugged from tweak app?
Mode switching needs to be done on the device that you use to record.
In USB Audio Recorder Pro, you can use the Master Gain control for this.
The threshold between Mono and Stereo is roughly -31dB there:
The Cosmos ADC's signal LEDs will light up green in Stereo and blue in Mono.
Reactions: Skj
Super many thanks. Great and useful post. I didn't know about leds for stereo mode. So master gain volume will not effect any recording volume this way? Where is that led in adc?
Also please help about tweak app. What does that read and connect does and what is the use of this app and how it is used. Thanks in advance.
I recorded a file in 768khz stereo without any input attached to adciso. The noise waveform is upto around -74db and there is slight difference in two noise floor of two channels around 3 to 4db. Is it ok ?
Skj, you didn't give us enough any details regarding the conditions of your test.
the input voltage is set at default 4.5v. its a 0 grade adciso unit. i recorded a 768khz wav file without any input. so imo it should record only the noise floor of the adc? i opened the file and zoomed vertically to see the limit of noise floor which is around -74db. shouldn't it be around -126 db or so ? if required i can upload the file. thanks !
On the previous page of that thread, you can find my explanation about how to test the noise of Cosmos ADC. Shortly, you need the FFT software REW, and mono-mode A-weighted result within 20Hz-20kHz at 48k of sampling will show <=-129db(A). ADC's inputs are not connected i.e. float.
thank for the response. now i understand that in floating condition the nose floor will not be correct. isn't it ?
i
On the previous page of that thread, you can find my explanation about how to test the noise of Cosmos ADC. Pls take a look.
Inputs are float means the XLR inputs are not connected, and no cables are tied to these inputs.
i also did not connect the cable in the input but still got -74db noise floor ?
Sorry, I have no idea what you measured and how, hence, I can't make any conclusions about that. I said how to measure Cosmos ADC noise with REW, or with AP:
BW 20-20k A-weighted, mono-mode, Fs = 48kHz. I guess you measured the DC offset of the ADC which is not an audio noise floor.
PS: REW is FFT(and more) software https://www.avnirvana.com/threads/v5-30-beta-release.12707/
i
Hi,
like @IVX said, it's certainly the DC level. You need to open the file in a player with frequencies analyser, this level will only be around 5Hz and lower.
Easiest check is to install Spek ( https://www.spek.cc/p/download ) and load the file
EDIT: said "Spek" a bit quickly as it's not the best to check such low frequencies level, but it's the quickest to install and use
Reactions: Skj
Hi,
thanks got it. analyzed the recordings. i also analyzed after removal of some dc offset too. pls see. all files were recorded without any input. seems to be fine after dc removal
