E1DA Cosmos ADC
@staticV3
I take note of SNR/SINAD values for audio technology, but it is much more important for me to look at a corresponding FFT. It is clear that a measuring device like the Cosmos ADCiso must also have high SINAD values. If necessary, I use a Y-cable.
With your graphic you have described what I had in mind. With Mono Mode (L) and (R) are connected: So it doesn't matter which input or which output is used.
The Cosmos ADCiso internally reduces the signal taken from the right by 50 % (-6 dB) for the left (Mono Mode). By connecting the inputs in parallel with Y-cable (necessary for a maximum possible noise reduction of around 3 dB), we get 100 % again.
If you do not want to use a splitter, then Mono mode is useless
Of course you're exaggerating a little bit now.
RME ADI-2 DAC AK4493 (L / 0 dB) via input R or via Y-cable to Cosmos ADCiso (ADCiso: Switch 6.7V / REW: Output R or L / 1 kHz / -1 dB):
(M2)_RME-ADI-2-DAC-AK4493(L_0dB)-Cosmos-ADCiso(Mono_R)_1kHz-1dB.jpg(M1)_RME-ADI-2-DAC-AK4493(L_0dB)-Y-Cable-Cosmos-ADCiso(Mono_L)_1kHz-1dB.jpgRME_ADI-2-DAC-AK4493_THD_Outputs-XLR_RME.jpg
The difference between possibly 50 % mono mode (input R / REW output R) and 100 % Mono Mode (Y-cable / REW output L) results in a loss of noise reduction of about 2 dB.
An estimate of the input impedances of the ADCiso with switch 6.7V (ADI-2 DAC: output impedance 200 Ohm @1 kHz (RME specification) / voltages measured at the XLR input): Cable to R: 2.31k | With Y-cable: 1.15k
With the RME specification of the ADI-2/4 Pro SE (output impedance 213 Ohm @1 kHz) we get 2.46k! The ADCiso should have 2.46k (frequency was not specified).
All measurements with an average of 32 and stop at 31 for better comparison. But you get what you see: an addition of the signals (by magnitude and phase) from the DUT and ADCiso. Since the THD measurements were taken without a notch filter, the result is only a rough estimate (with small errors probably up to about -120 dB) of the functionality of the DUT.
Source
E1DA homepage:
"THD @ 1kHz @ -.5dbFS BW 22-22kHz <.00003%(.3-.2PPM) typical for 32b/48kHz all harmonics level -135-145db"
In addition, the THD+N value of the ES9822PRO limits the usable result:
ES9822PRO Product Datasheet / Performance:
Test Conditions (unless otherwise noted)
TA = 25°C, AVCC = AVCCL = AVCCR = +4.5V, AVDD = +3.3V, fs = 48kHz, MCLK = 49.152MHz, I2S output
THD+N Ratio @ fs=48kHz, BW=20Hz-20kHz: Typ: -117 / Max: -114 dB
Nevertheless, it is a pleasure to work with the ADCiso and there is no alternative for the purchase price!
Thanks for taking a look at this!
The ADCiso was purchased from AUDIOPHONICS a few days ago and it should be grade A (wooden box and circuit board are marked "A").
weme, If you asking something, don't neglect question marks, please. Cosmos ADC grade A should have noise -128db(A), in the mono mode, sampling is 48kHz, BW20-2000Hz, 27C is room temperature, and inputs are float.
If your FFT above made in stereo mode, your mono result will be close to grade 0. In the case of your ADC already in the mono mode, the Left channel shows (L+R)/2 noise, and 127.5db(A) looks slightly higher. I have to say that my AP SYS2522 is slightly more optimistic than REW, and usually, I see .2-.3db less noise than in REW. Sometimes, users may improve the noise performance by adjusting the ADC_INT_SEL parameters in Cosmos_Tweak.exe(make a screenshot of all calibrated parameters before you change them!). ADC1/ADC3 correspond Left channel, and ADC2/ADC4 Right. The default value is 11, you can try to change it to 7 or 15 with simultaneous control of the FFT noise result. I know a few cases when ES9822 got one ADC_INT_SEL value as the optimal on my bench but users reported that it wasn't optimal on their desk.
Cosmos ADCiso(Mono)-Y-Cable vs ADCiso(Mono)-Cable-to-R
The following measurements were taken in Mono Mode: SR 48kHz, Temperature 30°C (ADCiso in a temperature-controlled insulated box), BW not restricted or (20-20000 Hz), Balanced Connection, Inputs are open
SNR-1:
Mono Mode + Y-Cable + REW Input Channel = L <-- Ri of ADCiso = 1.23k
-125,19 dBFS (-127,5 dBFS A)
-125,49 dBFS (-127,6 dBFS A) BW 20-20000 Hz
SNR-2:
Mono Mode + Cable to R + REW Input Channel = R <-- Ri of ADCiso = 2.46k
-123,25 dBFS (-125,6 dBFS A)
-123,54 dBFS (-125,6 dFBS A) BW 20-20000 Hz
SNR-3: *)
Stereo Mode + Cable to R + REW Input Channel = R <-- Ri of ADCiso = 2.46k
-123,25 dBFS (-125,6 dFBS A)
SNR-4:
Stereo Mode + Cable to L + REW Input Channel = L <-- Ri of ADCiso = 2.46k
-121,38 dBFS (-123,7 dFBS A)
-121,67 dBFS (-123.7 dFBS A) BW 20-20000 Hz
*) "(Right input is always mapped to the Right channel)"
SNR-2 (SNR-3) case gives me an optimal result: We get the highest possible Ri, the loss of 2 dB has no practical effect, for special cases SNR-1 can be used.
Influence on SNR values:
BW to 20-20000 Hz improve the dBFS values by about 0.3 dB.
Higher temperatures of the ADCiso improve the dBFS values only slightly, temperature changes from 25°C to 35°C do not lead to relevant changes.
ADCn parameter changes with the Cosmos-Tweak software do not bring any improvements in my case. Parameter changes must always be checked at higher SRs!
Who needs further background information:
SNR tolerances, THD+N, ... to the ES9028PRO
THD compensation of an ES9028PRO:
Benchmark DAC3 - 2nd Harnonic Distortion vs. Frequency
@IVX
"Finally, I want to place RIAA switch in the Tweak_Cosmos app but that will take time."
Activation of the RIAA function via an additional switch in the Cosmos-Tweak?
Also switching from Mono to Stereo via an additional switch in the Cosmos-Tweak?
Also both stored in the ADCiso, so that these switching are permanent?
Also reading out the current FW?
USB power socket:
How high may the maximum continuous operating voltage of the USB socket be, if the sequence (on/off) of plugging in the USB plugs was not observed in the event of operating errors?
@pkane
Using your Multitone Analyser programme with a Test Plan, we can also create such measurement series:
H2, H3, ... vs housing temperature of the ADCiso @1kHz
H2, H3, ... vs amplitude of the ADCiso @1kHz
To avoid having to manually transfer the measured values to a spreadsheet programme, it would be great if you had the time and motivation to create a text file that contains all the values of the measurement series in lines after a header line. This text file could basically be created for THD measurements and similar, so that no additional parameter would be required in the Test Plan.
@pkane
Result tables are automatically generated in the output folder for the test plan run (usually in C:\ProgramData\Multitone Analyzer\test-results\xxxx) folder. These are .html files that you can open in the browser. Here's an example one such for a 1k distortion test:
I did that under the slider control to have the ability to control from a PC as well. All slider's Tweak_Cosmos positions are memorized but Windows switches that accordingly to its volume slider. The reading FW version from the ADC isn't supported.
I mean such measurement series:
MTA_Test-Plan_Measurement-Series_PlayGain(1)_Example.jpg MTA_Test-Plan_Measurement-Series_Time(3)_Example.jpg
For example, to analyse the effects of temperature and input amplitude of an ES9028PRO (Cosmos ADCiso)- related to H2, H3, ...
One text file (*.csv structure) per Test Plan contains all the data from the single *.html files after a few header lines.
View attachment 331011 View attachment 331012
You mean like this?
I will be getting level 0 adc in next few days. I have two apu units and pair of rode nt1 mics. I plan to do live recording of small group. Any guidance for the best adc settings will be helpful. Is there any need to change the defat parameters of adc?
No need to change the default paramters. Just set the ADC to 10V input sensitivity for the best headroom.
10v i think will be too high. I plan to use apu in lower gain so 1.7v should do instead of 10v.
Dear @IVX , I tried recording with a single condenser mic to adciso with apu. I used 4xAA battery pack for both adc and apu. I could record for few minutes but after some time there was no signal to the app but the recorded silence. It means adc was working but apu stopped. Could it be the low power of battey pack? Also I heard some intermittent clicking in the recording. What could be the reason? I used usb audio recorder pro. It allowed 768khz 32bit wav. When I connected to xlr 1 ans selected input stereo 1-2 in the app i got one channel. When I selected mono 1,I got mono but when I selected mono 2, I got mono which was louder than earlier one. When I connected to xlr ans selected stereo 1-2 in the app i got recording in bitht channel but lopsided. If 4xAA pack is not powring ebough, can i use bigger usb rechargeable powe pack? Pls help. Thanks in advance. I have invested my savings in this set up.
What happens if phantom power is not switched off before mic is removed from apu? Does it damage the apu permanently and immediately?
As I think, you can unplug the 3.5mm input of the APU with 48V On state with not so high probability of damaging the APU like if you plug it in when 48V phantom power is On.
i.e. not 100%. Is the APU doesn't work after that?
You mean when I plug the mic to input of apu the phantom power should be off ? There is likely damage to mic if I plug it in when 48v phantom power is on or it will damage the apu?
Dear members, both apu working fine. I had problems in one of the battery pack so one apu was not responding. However some issues in adciso like I couldn't get the proper stereo recording through usb recorder pro Android app. I selected stereo 1-2 input, sample rate 768khz, bit depth 32. ( there is one more input tab which changes to stereo 3 for 32 bit and stereo 1 for 16bit and stereo 2 for 24bit. What those stereo 1,2,3,4 inputs for?However there seems to be mixed input from xlr 1 both channel. In windows when I select comtru asio in korg audiogate i could not select sample rate higher than 384khz and recording did not start. Any other windows app which allows asio input and 768khz rate?
