Thank you for the link!@Groom, you can anytime check the development and support of these boards here: https://discord.gg/AAus72ZEpu, where you can also contact Ivan in person. On Discord he is way faster in answering to your inquiries than he is here on ASR.
However, given the new Cosmos APU (see may previous post with teardown and measurements link) that can be "attached" to the Cosmos ADC, the 120 dB SINAD can be easily surpassed, so you may grab them both if you intend to measure audio devices above the 120 dB SINAD limit.
Looking forward for your thoughts on this ADC and details about the setup used.Will test it with my preamps and fx-chain.
User errorLooking forward for your thoughts on this ADC and details about the setup used.
Also, as a preamp, you can try the APU as well, given it's internal low-noise and the selectable 34dB/60dB.
I encountered a severe lack of resolution and narrowing of the stereo image when inserting the two (reverb tails completely gone etc.).
I expected a phase problem and tried different balanced cables and adaptors - they all yielded the same results.
Source: https://e1dashz.wixsite.com/index/cosmos-adcMONO/STEREO modes are switchable by the UAC2 volume commands, for example, if your Windows volume slider position is less than 50%(0 to 49%) the device works as 2 channel ADC, if more than 50% it is a MONO ADC with summed Left+Right inputs mapped on the Left channel(Right input is always mapped to the Right channel). In the MONO mode, both channels need to be tied together L+ to R+, L- to L-.
I use a Mac. How should that happen?Sounds like you might have Cosmos ADC set to mono mode, so the left channel is a combination of left and right:
Or is mono mode the default setting?
But this is exactly how it sounds.
Thank you!
Thank you!Sounds like you might have Cosmos ADC set to mono mode, so the left channel is a combination of left and right:
On Monterey I had to set it to 0 (mute) to make it work but now it´s fine
Do you have two usernames?User error
No, only one.Do you have two usernames?
I see you have deleted the message plane was replying, wondering why.
One more question if I may, could you explain how to activate the Riaa curve on a Mac?
Thank you again!
