IVX
The latest Cosmos Scaler front panel version, I like laconic style
Well, I did nothing special, just selected ASIO via the AP I/O settings, see pic.it is ok but pls tell me hoe did you get Comtrue ASIO works?
This is what I wrote to you before:it is ok but pls tell me hoe did you get Comtrue ASIO works?
HpW blacklists ComTrue, so you don't see it at all.
As I told you, I need just 1-2 minutes to add Play port to the ADC FW and I did that, however, REW still doesn't see CTASIO even it is a duplex now.
Comtrue says ASIO should work but it doesn't. BTW, the single Play ASIO interface i.e. DAC(not a duplex) works fine with REW and others.
HpW, we working on Cosmos Analyzer SW, where will be included tweak functions and more for instance ADC auto-calibration in one click.
CosmosAdc_v13.hex is latest one.
For whatever it's worth, REW on Linux works fine with the Cosmos ADC.
HpW, try walking in my shoes, pls. I a single person do all things simultaneously. Where I can get time to make a custom FW for 22/24MHz osc?
What is a false statement. There is may an other reason about.
That may be. I remember I had more ComTrue issues first because the download link on AliExpress was (or is) wrong. I then used the link from Archimago, and CT started to work.
You mean CT7601 Windows 7/10 driver 6.0.1.20210429 for the driver to use??
6.0.1.4031 according to Device Manager.You mean CT7601 Windows 7/10 driver 6.0.1.20210429 for the driver to use??
But I use ASIO4All with the CT driver and Cosmos, not the CT ASIO. And ASIO4All seems blacklisted in HpW.
