IVX
ADC runs as a master.
220uF gave -3db at 4-5Hz, 10uF will set that to the 90Hz if that's fine, you can try.Well, I guess that swapping the polarised caps with non-polarised type, like anything between 6.8...10uF MKP will dramatically increase the max. DC input voltage range, right? However, size and price would increase a lot, so not sure it worth it, unless it's really-really required.
I confirm, it is not due to input caps (sadly). I bypassed them and got the same performance as with them in the circuit.I invite @WolfX-700 and @IVX to comment the above graph, but I would say that input caps are not the cause for the increased THD+N on the low end.
do not normalize rip vinyl rips please, completely ruins them.Yes. This would require a line-level input, and could work with a standard setting for level (providing a bit of headroom for later normalization).
Rick "who currently uses a Benchmark ADC for that purpose, but it's a bit overkill just for that" Denney
Huh?do not normalize rip vinyl rips please, completely ruins them.
Hi @IVX and thank you for your answers. I have the exact same question. I would links to use the Cosmos with this preamp http://www.lineaudio.se/2MP.htmlald0s, how high the output voltage do you expect from your mic-preamp? Cosmos ADC has the 0dbfs voltage 8 steps switchable from 1.7Vrms to 10Vrms.
