Actually, [email protected]. 0dbfs about 1.8Vrms.
no, because this is inverting stage.Is there any 0dB input gain settings so no gain nor attenuation's applied? As like to understand the 3.2Vrms as given on spec's
You need to be more specific, please.is it snake oil, like this small?
Do you want me to measure those caps from the input LPF?Referring to the pic in post #30, have a perhaps circled an eventual LP filter? Values of caps?
Or where and how?
You will need a High speed USB2 one,like the Intona's.Anyone managed to make an USB isolator working on the Cosmos ADC? I tried one from Amazon
https://www.amazon.se/Nobsound-isol...b6-b99a-20cb22334e5f&pd_rd_i=B07GF6VMMK&psc=1
but it was a no go. The change of mono->stereo by changing the volume slider on the laptop seemed to work but ni sound - only static...
I would get the 4165 which is available,the other is not till juneThanks!
Yes, quite a bit lower - an eval board would be ok. Hmm, which one do I want?
"The ADuM4165 supports the clock or crystal input on the upstream side, and the ADuM4166 supports the clock or crystal input on the downstream side"
I suppose it would be best to let the Cosmos be "master" and take the clock from there - but is this up or down-stream? Don't get it...
Its very good also that this board support individual powering of the Cosmos - it is needed because my Laptop battery is not so good anymore and my phone dont have that much juice.
I hope the EVM would also work between a phone and the ADC - I managed to succesfully connect the Cosmos to my phone using https://www.extreamsd.com/index.php/products/usb-audio-recorder-pro and do proper recordings.
Aha - not even the Intona... wow.. hmm.. what is the problem (with the Cosmos?)?
I think @pma uses (a not high speed) one and it seems to work,maybe he'll jump in to tell us.
- if DM+ would work with OPTO-ISO (I do not know, some soundcards do not, like Focusrite 2i2. Cosmos also does not work with USB-ISO)
...and he uses windows,so @pkane 's Mac is not the drawback.He said it doesn't work with the Cosmos -> https://www.audiosciencereview.com/...cs-do-they-sound-different.41363/post-1462127.
Michael
