Better if the designer could explain whats the problem with the Commons ADC... but he doesn't seem to think its of any use so not so inclined to discuss the matter as it turns out... maybe a few has some need that he don't have...
This is purely DAC output, no LPF is involved
Need to see what is happening past 30kHz to determine if clean?I'm thinking, should I add the LPFs there if ES9038Pro looks so clean already?
I guess you misunderstood about the LPF I mentioned. The LPF in the I/V stage is in action(at Fs/2), but the initial idea of Cosmos DAC was to use additional LPF at 1kHz to wipe out the residual noise and harmonics to use as low-distortion sine gen.Need to see what is happening past 30kHz to determine if clean?
Do you have equipment that can show up to 1MHz ? With linear sweep 0-22.05kHz ?
Ah yes.I guess you misunderstood about the LPF I mentioned. The LPF in the I/V stage is in action(at Fs/2), but the initial idea of Cosmos DAC was to use additional LPF at 1kHz to wipe out the residual noise and harmonics to use as low-distortion sine gen.
Thanks! What about the other question from the end, please?Hmm, what kinda file, as you can see this is a plain REW GEN.
Do you mean cost? I have to decide if I need here USB ISO(ISOUSB211 I can buy today for $20 as an example), and 1/10Khz LPFs.Thanks! What about the other question from the end, please?
From the European perspective, it is easier if an item's price is at most 150 EUR, not including taxes or shipping.So I guess the only Cosmos DAC should be no more than $100 or so![]()
Scaler is coming first right?Cosmos line uses 90x50x1mm PCB.
