nick_l44.1
- Joined
- Jan 11, 2024
- Messages
- 119
- Likes
- 83
That’s how it heats up under moderate load.temperature of the E1DA 9039S
Naah!I've seen some comments with cooling suggestions. Out of proportion with CPU coolers and such, just people modding around. But how is it in reality?
Where did you get that figure from ?
It's rather around 105dB (@100mW, 32 ohm), as per Aiyima's own specs (H4).
For a desktop device, sure.Actually, I'm surprised that the number is this low since the E9039Q2M usually does get to >120dB SINAD.
The size of this box would also be linked to engineers pride. Big is easy. Just big enough is smart.While I agree a 4.4mm connector would be more practical, I also think size is important.
I really like it small !
The output impedance of the 9039s with a 2.5 connector is only 0.1 ohms. It can already be considered ideal. From my perspective, the 2.5 connector is more ergonomic because all my headphone cables use the 2.5 connector. Although I understand your concerns, as well as why IVX isn’t eager to use the 4.4 connector.They could make it bigger with a 4.4 plug and the power output could be even better.
As far as I understand, the APx generator doesn’t have any outstanding characteristics. But it’s calibrated in much the same way as REW anti-harmonics works. And with this approach, it’s possible to obtain a test signal with very low THD using almost any DAC.That's better than AudioPrecision and almost anything else I'm aware of, desktop DAC included !
How is it back home?Nah. South of France.
I'm back home now.
This is not sinad or THD+N(which is the same thing as sinad), on your plot is bare THD. THD@1000Hz of 9039S at 16.2ohm load, I see -130db with 3.34Vrms 698mW vs 100mW at 15.8ohm on your plot. So, 120€ 9039S has ~7 times more power with 15db lower distortion, but no EQView attachment 550335
This is the Fosi DS3 according to RAA. It has selectable filters and PEQ for around 110€.![]()
This is not sinad or THD+N(which is the same thing as sinad), on your plot is bare THD. THD@1000Hz of 9039S at 16.2ohm load, I see -130db with 3.34Vrms 698mW vs 100mW at 15.8ohm on your plot. So, 120€ 9039S has ~7 times more power with 15db lower distortion, but no EQ![]()
It has an 9039 but isn't that dongle more aimed at gamers / desktop users / a somewhat pretty decent soundcard replacement?This is the Fosi DS3 according to RAA. It has selectable filters and PEQ for around 110€.![]()
