nick_l44.1
- Joined
- Jan 11, 2024
- Messages
- 132
- Likes
- 86
I’d like to say a few words about the differences between these prototypes (yes, I have one too) and the latest production samples.Granted, it's a sample (possibly) cherry picked by Ivan for measurements.
Of course, the review prototypes were thoroughly tested and selected, but only from a small pool of similar prototypes. Recently, I had the opportunity to compare my prototype with a newly released dongle. And it was quite surprising to hear something new, albeit in a homeopathic dose. It seemed that the low-frequency response had become sharper. It would be logical to assume that high-frequency distortion had decreased, which could very well be the case, since the production dongles feature a larger power supply filter—4,500 μF compared to 3,000 μF in the prototypes. It has also long been known that even the first production units performed slightly better than the prototypes in terms of THD+N. It turned out that not only had the capacitance increased, but the tantalum capacitors had been replaced with solid-polymer ones, and there were other revisions as well. I can’t say for certain that the changes are audible, but overall, the hypothesis was confirmed.
The 9039s, when unloaded, shows a unique THD@10kHz value of about -130 dB. The idea was to check how much this figure degrades under load.
The Notch allows for precise measurement of distortion only at 10 kHz:
Prototype. THD@10kHz@32Ohm = -108.9 dB
Production sample. THD@10kHz@32Ohm = -112.5 dB
The difference is only 3.6 dB, but it’s there. And by 20 kHz, it increases to 5 dB.
It is possible to measure more precisely and further adjust the THD compensation calibration, which can yield peaks even lower than -150 dB:All distortion peaks are below -140dB !
I also have a Topping HS02, and I absolutely dislike it: mains hum bleeds through it, and it provides very mediocre power quality. If you encounter issues with power purity, it’s best to measure the power characteristics by connecting a good power bank via a Y-cable.I use the Topping HS02
jkim has already measured this. Here are my results:Can you measure the THD+N at 50mVrms output?
