E1DA #9039S Balanced Portable DAC/Amp Review
Rja4000
Liège, Belgium
Here is a review and measurements of the
E1DA #9039S balanced USB DAC and Headphones amplifier​
The #9039S is VERY small, as you may see on the pictures, where it's laying on my Samsung S23 Ultra.
And it weights a mere 12g.
I received it for free from Ivan (Mr E1DA, aka @IVX) for measurements in 2024.
But only now, with the new AudioPrecision APx 500 Flex 10.0 software, I can run all our usual tests, since it allows different device drivers for output and input.
I see it announced at prices ranging from 122€ to 170€ here in Europe.
Is it worth the money ?
First an important note:
This is a BALANCED ONLY DAC/amp.
DO NOT
connect an unbalanced headphones or load to it or you may break it !
It comes with a USB C port and a 2.5mm Balanced output connector.
The only form of feedback is coming with a small white led next to the USB connector.
Technically, E1DA tells us it's based on an ESS ES9039Q2M chip and uses OPA1612 and AD8397 high quality OpAmps.
Measurements​
Measures are performed with following equipment:
RME ADI-2/4 Pro SE, as the main ADC.
For very low levels, I used the RME 12Mic-D Mic preamp/interface or the RME UFX III interface.
To get the last bit of performance for SINAD measurement, I also used the E1DA APU with notch filter.
For this review, I used Audio Precision APx 500 Flex 10.0, where possible.
Some measurements were done with my ususal software, Virtins Multi Instrument (now version 3.9.16).
There are some limitations and differences compared to Amir's testing with an Audio Precision APx555.
That's more than enough to get a good idea of the device performances though.
I'll post comments where such differences are most important.
SINAD measurement​
NB: I don't own an Audio Precision analyzer.
Conditions are therefore not exactly the same, so please don't compare this directly to Amir's figures.
Any value approaching or above 120dB SINAD should be considered state of the art anyway.
For this measurement, I used the APx 500 Flex software, with the RME ADI-2/4 Pro SE and an external E1DA APU notch filter.
I can only measure one channel at a time, This is left channel. Right channel is similar.
Now that is something from such a tiny device, isn't it ?
All distortion peaks are below -140dB !
We don't reach 4V: max level is 3.5Vrms.
Dynamic range​
Important: this is A-Weighted, to compare with E1DA specs.
I re-measured with all 3 usual weighting and got following (slightly better) results :
Linearity​
Multitone​
I don't have an explanation for low frequencies.
It's more than good enough, anyway.
Output impedance​
(balanced) output
Open circuit Voltage (-3dBFS)V12,486Vrms
Load resistanceRL12,3Ohm
Loaded circuit VoltageV22,470Vrms
Zo=RL*(V1/V2-1)Zo0,08Ohm
It matches the announced <0.1 Ohm at 1kHz.
Measured with a calibrated Brymen BM869s
IMD+N measurement​
Compared with the Topping D50 III, which uses 2 of the same DAC chip, we get equal or better performance, which is impressive.
Jitter​
Filter performance​
Signal to Noise Ratio at 50mV​
Here we have real measurements. (997Hz, 200k ohm load, both channels averaged)
But, as usual when there is no analog attenuator, SNR at 50mV could have been deducted/computed from Dynamic range with reasonable accuracy.
That would land it around here in the ranking of all Headphones amplifiers tested:
Voltage vs Impedance​
I didn't use the E1DA APU notch to measure this, so we don't reach the same SINAD level, but that's limited by the ADC, not by the DAC.
This is incredible performance from such a small DAC !
Impedance has no impact until 16 ohm.
And with 12 ohm, it still pushes >2.6Vrms.
All figures here-above are reached with SINAD >118dB !
I didn't reach the spec for 12 and 16 Ohm.
(Maybe because it's very hot here today: Temperature in my room is 34.5°C right now !)
The difference is less than 1dB though, so negligible...
Power profile is clearly oriented towards low impedance headphones.
NEW:
Another way to represent the power vs impedance is to use dBW (10*log10(W)) and Ohm on a logarithmic scale
And ideal amplifier should have all measurements as a straight line.
[Note: the dBW scale is wrong above (should be dBmW instead of dBW), sorry. I will correct it ASAP.]
We see that the #9039s behaves as a perfect amplifier -only limited by its max output voltage- for most impedances.
Only below 16 ohm, we start to see some current limitation, but it's still pushing hard !
With my insensitive Dan Clark E3, I can get more than enough SPL for my taste - and I like it loud !
Amir measured the E3 as 27 ohm and he says 512mV were required to get 94dB SPL - so we should get around 110dB SPL without added distortion from the #9039S.
Note that, the #9039S gets quite hot:
I measured around 47°C on the surface after my (admitedly very tough) tests.
Conclusion​
How to say ?
Granted, it's a sample (possibly) cherry picked by Ivan for measurements.
By the way, he was quite frustrated, because he thinks I could get better measurements still.
(Archimago was able to get even better figures - so I think Ivan is right...)
But is it worth it, anyway ?
What we have here is plenty enough to demonstrate the device's capability.
This is more than excellent !
This is better than good - it's world class for such a tiny devices.
And even if a random sample gets 1dB lesser figures (?), it still measures way better than anything on the market in that category to date.
No, but it's still a very good thingy. :)
Well, my point of view is that even if I had to pay for it, I'd do it.
I was using the Topping G5 before to listen to music at work.
With this one, I can drive the E3 to neighbours-disturbing levels without any distortion coming from the DAC/amp...
And with no added bulk or size vs the E3 and its cable...
I also tried the Tanchjim Space, but it distorts badly at the volume I want.
In Liège?
By the way, he [Ivan] was quite frustrated, because he thinks I could get better measurements still.
Maybe you could but it might take a higher power microscope to see it.
Congrats on being able to perform measurements with such precise detail.
Probably clock difference between source and measuring ADC? Is it synchronous?
Price is OK for a small lot production.
We don't live that far away... don't you have air conditioning? 34 degrees is crazy—it's even dangerous, man...
Very happy with my unit. It can get very hot but I think this is some type of error case - reset it - normally its "warm"...
What power feed did you use - I suggets for a serious measurement you need a USB isolator with an external separate high quality 5V feed for the load. This make for two things - isolate away the phone from the DAC and offer quieter power source....
So these are more or less given away now... hmm.. new version in the works?
That kind of market move is never good for the brand value however....
Well, power measurement tests are not really kind with hardware...
So hot is quite normal.
It's not "burning-hot" anyway.
Oh really ? :)
I use the Topping HS02.
The ADC is powered from battery.
As for the DAC, power is coming through the isolator.
This one is the "New" version.
As explained above, they are not really "given away".
How long does the S23 Ultra last with the dongle playing?
I don't know.
I use it at work, between meetings, so difficult to say.
It of course also depends how loud you play :-)
And I use a wireless charger with it when required, so not really an issue for me...
Excellent! Could be used as a very portable perfect generator. Can you measure the THD+N at 50mVrms output? Just for curiosity.
For an even better 1kHz generator, E1DA has a $75 LPF board intended for the 9039S. But you loose portability.
Wouldn't something like the NICEHCK Octave or the Fosi DS3 satisfy a similar need for around 100€, with the addition of PEQ? :)
Of course, there are no independent measurements for those, as far as I'm aware...
Edit: there is also the Aiyima H4 without PEQ...
