I thought you were talking about mains leakage. Not general USB noise. The analyzer input is band limited to 22.4 kHz in testing so not sure what hundreds of kHz and MHz has to do with the measurements I show.@amirm, Your PC HF noise isn't AC main 60Hz, there are from hundreds kHz and up to hundreds MHz, and 1uF at such frequencies is shorter than your USB cable(any 1uf MLCC has 10mOhm of ESR typically and 1-10MHz simply shorted by 1uF to the AP chassis, hence, to its GND wire, next few meters to your PC GND, and returns with USB cable back).
Plenty of people use computers with these dongles, specifically laptops. So the source is not always battery powered. When used on Android and such, the OS stack messes with the samples with default making any such refinements in measurement moot anyway. In addition, desktop DAC+Amps are subject to the same condition in their headphone out. They don't seem to be in need of creating battery operated setups to test them.sure, if you use a DAC when lay in a grounded tub full of water, you have a slightly similar GND loop. Normally, you are well isolated from the GND, and doesn't matter grounded PC in use or battery-powered Android. Hence, the most realistic method of measurement is isolated USB source, or isolated AP, or correctly grounded entire setup. As a criterion of how far your AP+DUT setup from an ideal, you can compare that with a battery-powered USB source(Android) as a nearly ideal sample. Using the unbalanced input without isolation is the worst case ever.
I can imagine he's like a Dad with a newborn child-perfect and beyond reproach. I just ordered one and I am certain it will sound great so no worries.To be very clear, here is the dashboard:
The limiting in performance is third harmonic at about -113 dB or so. Add just a tiny amount of noise in the analyzer and the dongle and you get down to 111 dB SINAD as shown. Yes, there is some low level noise but that is the "grass" well below the harmonics at -140 dB. No way is that our concern, nor is it shown to be the reason distortion is what it is.
Also, as noted much earlier in the review, I allowed the dongle to be tested at 2.7 volts rather than 2 volts. That should have helped it get slightly better performance in SNR/DNR, offsetting the small amount of noise bleed into the device (from whatever source).
Really, I have never seen a manufacturer be so unhappy with what is a great review. And high praise of the designer.
People are getting confused thinking any and all measurements including testing speakers is faulty. Nothing like that is remotely the case.
it is not about my product but about scientific principles. The truth has priority #1, not a high mark, and not money. Your setup shows its own noise, I already a few times said what needs to change in that setup to turn the science On.What I can't figure out is the source of complaints.
I did that directly to the 3.5mm plug with 6mm PLB traces, as you can see on my pic, AP's chassis tied with one more croc-clip to the USB-C shield. That's it, that setup has minimal difference vs isolated Android.
What science? You haven't shown the impact of the issue on the measurements. The main impairments are 0 dBFS clipping and third harmonic.it is not about my product but about scientific principles. The truth has priority #1, not a high mark, and not money. Your setup shows its own noise, I already a few times said what needs to change in that setup to turn the science On.
I don’t know what it is, but I would recommend
It's not about the clipping though. IVX is saying, when using a slightly different set-up to measure the 9038d direct output, with better CMRR the overall output will look cleaner (so third harmonic will also be lower supposedly, and overall SINAD might increase by at least few dB). That is from his own testing. As Amirm measured now, it shows the 9038d more in a line-out use case to another device and not as a straight output to, like @MC_RME worded it nicely, "a floating, earth-free headphone." which will perform (even) better than what is currently shown here. Wiring it a little differently to the APx, you could maybe simulate that.. but it's yet another measurement step, I guess it won't happenI bought a 9038D and like it a lot. However, the response I am seeing here from IVX is highly irregular for him. I don’t know what it is, but I would recommend to him to get it settled. Normally, he is pretty easy going and very open when people give constructive feedback. People know him enough to know where he is coming from and his decency and integrity. But for people on the outside looking in, this might be a bad look. Honestly, if I were him, I would take @Amir’s feedback to heart and apply the fixes he needs to rectify the clipping. If I were him, I would be pleased to see Amir raving about my product and giving it his recommendation. I don’t know if he is feeling salty about the S9 getting the upper hand in the measurements, but Amir’s test setup doesn’t lie about the clipping. [...]
In any case Amir has shown the 9038d measures very well. IVX is simply saying from his own testing, in real-world application it might perform even better due to the reasons mentioned.
This is nothing the dongle can be blamed for... Being powerful enough to drive full size cans doesn't work without current. I could imagine a situation on a business trip when charging the phone is possible and 4G/5G not relevant... On a plane or in a hotel room for example. Usage of a y-adapter for supplying energy from a powerbank or similar was also mentioned.
