IVX
dvdblaster, no problem, 9038D will provide 2.75Vrms at a typical10kom input.
YesCan the E1DA 9038D be used as a dedicated DAC for a headphone amp, like the Topping L30? Also, I’d like to know whether the DAC would input close to 2.7V into the amp in this setup, or less. Thank you in advance for the responses
Makes sense ! Still don't know why it should be free.Jimbob54, the max limit often needs folk with sensitive IEMs to avoid crazy-loud shock. The min limit you can like to use to make the volume slider response more "linear" if that looks too much "unlinear". For example, Win10 + Comtrue driver makes the Volume slider work from 60% to 100%(0 to 40% just silence) at my HE400i, so I can set the min limit at -50db and get slider work wider, 10% to 100% is much better than 60-100, right?
I have seen no other dongle that has such a small usable volume range in my setup. So for my particular case (iPhone + Sundara, pretty common I guess) it’s an issue. Having a solution is great, having to pay 10$ for it is not.Since when is the ability to configure the hardware volume range that is accessible via UAC2 commands (remember: that's not the same as plain hardware volume control via UAC2) a basic feature of dongles?
Do you know of another dongle with that level of customizability?
Other dongles exist with much more customization (EQ for instance) and that don’t have this issue for me. And their app is free.
i already said 10$ for the app is steep given the limited interface and features, and that all other companion apps are free.
take a look at Qudelix free app for a benchmark.
E1DA still a great product, but no longer the only one and not perfect either.
curious about the new Shanling offering also with both 3.5 and 2.5mm, if it measures well it’s a great contender.
AFAIK "Standby" affects the DAC+OpAmps and "Mute" affects the DAC output onlyI understand (I hope) what "standby" switch means, but no ideas how "mute" switch in tweak app works. Could somebody be so kind to explain?
As is mine reading this'Your smile is already larger than your face is wide!'
https://www.stereophile.com/content/katzs-corner-episode-25-adventures-distortionAudioJester me too, I noticed that max(-50db) level of the 2nd harmonic makes me happier, than "trivial" THD+N 0.00012%. However, it very much depends on the music you listen to. Jazz, jazz-vocal, classic is fine with tonnes of 2nd harmonic but AC/DC nooo.
