Then your argument that my analyzer runs wideband but your audio gear doesn't due to simple RC filter doesn't hold.I'm pretty sure there is one.
And where is the certifications that this device has?Very important point there. It's not that DACs or amps must not emit any ultrasonics, they just have to stay within legal limits.
Not so. I measure both outputs of many such DACs. Difference is tiny -- usually 3 dB is so.It's clear that a balanced DAC output will be measured with balanced in
It is possible to supply data to the 9038D from your phone while supplying power from an external source like a phone charger or power bank, therefore preserving your phone's battery life.Thanks! I got my device with typeC-typeC wire but I would like to charge my android phone (at least have dedicated power for the 9038D to less intensive discharge) and enjoy music the same time. So might be someone could bring me light:
1) Does something like this work for it?
2) Should I avoid any "power noise" from my included Samsung power adapter?
Answer: slew rate.To continue this thought: what is the difference between a balanced headphone and a loudspeaker?
Answer: slew rate.
APx555 has wideband for a reason. If we were to always filter what goes into it, why on earth would they design it with 2 MHz bandwidth? They don't. The system does have a weak point which is called slew rate limiting. Switching class D amps have very high slew rate in the frequency range of their amps. The switching swings from rail to rail so has incredibly high slew rate, causing problems for the front end of the AP analyzer. For this reason, I use AES-17 (wideband) filter. A headphone amp with the same switching frequency would have far lower voltage swings so has much lower slew rate so doesn't cause the same type of issue for AP. Indeed, I have measured hundreds of DACs with switching power supplies or USB power input, none of which have show the type of problems you see when AP slew rate limits.
Note that the AP AES filter has very wide bandwidth:
Mine is rated for "40 kHz" but that only means that it is within AES spec in that region. As you see, it lets through the input almost unchanged until about 100 kHz. So it will not solve any issues with ultrasonic frequencies up to that region.
Finally, there is a cost to these filters. Here is the specs for my AES filter:
Distortion
< -110 dB harmonic (measured at 70 Vpp, 1 kHz)
< -100 dB IMD (at 70 Vpp with 18 kHz and 20 kHz dual-tone test signal)
This is not much of an issue for power amplifiers. But for DACs? It can degrade their performance to their much higher performance and cause its own set of arguments.
Does the ultrasonic noise from this device stay within legal limits when it drives Amir's AP inputs crazy?It's not that DACs or amps must not emit any ultrasonics, they just have to stay within legal limits.
E1DA 9038D Measurements (Headphone Amp)
Power is everything in headphone amps so let's see how much we have at 300 ohm:
OK, let me clarify:NM156, it seems we use completely different languages, I did explain that difference in THD+N at 300mW by 1.5MHz noise presented at one of the channels.
