Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 8,035
- Likes
- 10,516
What's the big deal about a waveguide? I mean how hard is it for a company to design one?
It came out in 2014 and has been discontinued. It cost US $1,500 then. I see used ones at almost that price.
A well-tuned waveguide, optimized for a certain baffle width is not trivial.What's the big deal about a waveguide? I mean how hard is it for a company to design one?
I once inquired at Dynaudio the reason for the missing wave-guide on the bookshelf 'Confidence 20' and on their top-of-the-line, pro-audio 'Core' series.They moved forward and now they feelconfidentconfidence about it, calling the new tech "DDC (Dynaudio Directivity Control)"
It's not just designing any shape around the tweeter and mid/woofer, but a repetitive process of computer modeling and checking with measurements until the dispersion meets their goals. Some manufacturers want full dispersion in every direction. Dynaudio wants to restrict vertical dispersion (on their higher end models). And some manufacturers want to restrict both vertical and horizontal dispersion. There are topics discussing the pros and cons of each here in ASR.What's the big deal about a waveguide? I mean how hard is it for a company to design one?
Previous Confidence DDC below.
A friend of mine upgraded from the Confidence C1 to the new Confidence C20 and was quite satisfied with the improvements, so if you like Dynaudio and their bookshelf speakers, the new C20 are worth it.And the original Confidence C1, bought in 2011. I don't have vast experience with other brands, certainly not at the C1s price range, but always was very happy with both of these. Don't let the review scare you away from the brand![]()
With this logic any faceplate or baffle can be called a waveguide. As we can see from the measurements though this particular 'waveguide' isn't doing a good job.Oh yes it is, see at 9:45:
I appreciate the suggestion, but unfortunately I don't really have much of a budget to work with these days. Even these I was only able to buy back then with a loan and them being a discounted demo pair, despite having a better financial outlook at the time. I took the risk to skip directly to the endgame from the Audience 42s when the opportunity arose. Any upgrade to them would cost crazy amounts. New Confidence 20 pair? Triple what I paid for C1+standsA friend of mine upgraded from the Confidence C1 to the new Confidence C20 and was quite satisfied with the improvements, so if you like Dynaudio and their bookshelf speakers, the new C20 are worth it.
The Core manual suggests that the acoustic axis is the mid point between the mid woofer and the tweeter, not directly in line with the tweeter:
Would adjusting the measurment position make a significant difference to the results?
I don't know if you're kidding or not.
I don't know if you're kidding or not. I'm hoping you are. But in the event you are taking their side here...
I don't want to get drawn in to a semantics debate. For all intents and purposes, that's a bevel.
What's the size of that bevel? 1/8"? So, it's effective far above the frequencies that we can hear.
