_Dekker
- Joined
- Apr 16, 2021
- Messages
- 21
- Likes
- 31
While getting my room optimized with this sub I ran into the desire to bypass the sub for measurements.
The manual states:
1: Disable: Trigger input is ignored.
2: ON/OFF: Trigger input is required to turn the 18S on.
3: Mute sub with High pass: Trigger input mutes the 18S with main speakers high passed.
4: Mute sub without High pass: Trigger input mute the 18s with out high pass filtering the main speakers.
So I tried to make my own trigger and share it because it's really simple.
All you need is a 5-12V adapter. I used a 5VC one that actually outputs 5.2V. I cut off the plug.
I had an old Sennheiser headphone cable lying around with 3.5mm stereo plug. These have that fork on one end which is convenient to solder the adapter cables onto. I just used the left channel fork.
Simply connect the + wire to the plug tip and the - to the plug base.
Insert a switch if you want. I was too lazy for this: I simply plug in the adapter.
It works!
Just to be complete, this is what the trigger 'on' setting does:
1: No effect
2: Trigger on: turns the 18S on.
3: Trigger on: Mute sub with High pass
4: Trigger on: Mute sub without High pass
The manual states:
Trigger (5 - 12 VDC = on)
4 options:1: Disable: Trigger input is ignored.
It works!
1: No effect
