Dynasty ProAudio UA2D Audio Interface & Phono Stage
Rate this interface and phono stage:
    Votes: 75 96.2%
    Votes: 2 2.6%
    Votes: 1 1.3%
    Votes: 0 0.0%
This is a review and measurements of the Dynasty ProAudio UA2D Audio Interface (DAC & ADC), Phono input and headphone amplifier. It was kindly drop shipped by a member and sells for US $58.
Dynasty ProAudio U2AD USB LP RIAA Phono preamp stage digitizer ripping analog DAC Headphone Am...jpg
I like the white case and of course, all the functionality. I do wish the case was heavier as the cables easy twist it around making it hard to access the controls.
Speaking of the controls, I must say, I have never seen one that goes from "preamp" to "CPU!" The terse manual explains that CPU means DAC output. In other words, you can mix an analog input with what your DAC is playing. What for, in this class, I don't know. It sure made configuration of the device complicated. A nice green LED indicates input being there although it is placed after the input stages. As a result it goes off even if you have a single present but gains set low.
You can use the unit stand alone with RCA in and out. Or power it through USB and use it that way (it stayed working even without the external power supply).
Dynasty ProAudio UA2D Measurements
I adjusted the gains to achieve 45 dB and ran analog dashboard:
Dynasty Audio U2AD USB LP RIAA Phono preamp stage digitizer ripping analog measurement.png
This is not that good of a performance, degraded by noise and power supply rectifier noise:
I next attempted to test the main reason for this device: digitizing the input. I spent some half hour to an hour trying to get this to work but it simply would not. Windows would recognize the unit and I could capture signal from it. But the level was hovering at some -90 dB. I could change the signal fed to the unit and could see some interactions with the output so the connection was going through. But something must be disconnected between the ADC and the phono stage.
To make sure it was not a driver issue, I tested the UA2D as a DAC and that worked:
Dynasty Audio U2AD USB LP RIAA Phono preamp stage digitizer ripping DAC measurement.png
That is, if you call this "working." Above is the best I got as anything higher than 1 volt output would add insult to injury by producing much more distortion. Compensating for FFT gain, noise level is around -65 dB which is quite poor.
Strangely, the device exposes 8 channels of audio to Windows! I wonder if it is using a DAC that has 8 channels. Feeding all the channels or just 1 & 2 would make no difference so not a performance issue but odd nevertheless.
I searched online and in amazon reviews and found people complaining about the same thing (not getting signal through USB) but no solutions. Seemed to be an issue with later hardware/software which mine is (windows 11).
So stopped here.
The functionality of UA2D is right on the money. The cost is unheard of for what you get. Sadly, quality control must be lacking on top of poor performance. A rev 2 of this device selling for even more money, say $99 to $149 that works properly would be a killer.
Needless to say, I can't recommend Dynasty ProAudio UA2D.
Yes I can see why, but thanks for testing it.
Published spec's;
Specifications:
-Signal and peak LED indicators
-Built-in low noise phono preamp circuit
-Frequency Response: 10Hz-20Khz, +/-.5dB
-THD: 0.01% Typical @ 1KHz
-Hum & Noise: >89dB below clipping
-Maximum Input Level: 40mVrms @ 1 Khz (phono), +19dBu (line)
-Analog Output Connections: RCA (preamp line output), 1/8” Mini-Jack (USB monitor/headphone output)
-A/D & D/A: 16 bit, 44.1Khz or 48Khz USB selectable
-Computer Interface: USB 2.0 compliant, Windows 98, XP/ Mac OS9.1 & X 10.1 or newer
-Microsoft Vista Premium Level Compliant
-USB cables included
-Dimensions (LxWxH): 113 x 73 x 40mm
-Weight: 0.22 kg
I have no pics of this as yet to post...
JSmith
Apparently, it’s not even heavy enough to make a good doorstop!
Fail.
Well the phono stage works, and the DAC works as well as an Audio GD unit, and people used to pay big bucks for that level of "tubelike" performance. So good job there Dynasty! And looks like you could do some mixing? And there's a headphone amp too? Too bad the ADC doesn't work.
All in all, looks like a stocking stuffer to give a 10 year old who wants to be a recording engineer when he (she) grows up.
Thanks for the review of this headless panther, Amir.
Features look great for anyone with both a TT and a computer on their desk, console or bench. But I think the MIX knob would be better as a switch to choose between USB and phono inputs.
Thanks to the member and Amir for the public service of showing us that it's a no go.
Amazon (not exclusively but mainly) wil just sell everything to any sucker...
Don't be a sucker and buy something that does more than just 'function' :)
I would only gift this to my worst enemy. And then still. A ten year old will be at best confused, and learn nothing from this device. Keep out of reach of children:)
Another totally broken device... I really don't understand how any company ships such a product.
Sad that devices with cool functionality so often lack good quality.
Thank you for another review and another sad outcome.
If an an audio manufacturer is wanting to "reinvent the wheel": the least they can do -before final packaging- would be to spin it.
I am just relieved that I am not the only member to submit knee-capped products for review
Poor thing cannot even qualify for a 'doorstop'!;)
OT: A contract engineering firm should devise a proper ADC (<$85), as a plug-in board/module. We would not have to shame such upstarts.
So stopped here.
I am always in the market for a cheap although good performing USB audio interface, but Headless panther gave it away :) Did not even need to read the review...
