Dutch & Dutch 6c
Thank you all for the feedback! I completely understand and respect the objectivist philosophy of ASR—in fact, the stellar objective measurements of the Dutch & Dutch 8C were the primary reason I chose them in the first place.
I shared my layout as a holistic project where I wanted to optimize every variable, including mechanical isolation and power conditioning, even if their margins of improvement are micro-level compared to macro-variables like room acoustics
I think the general view here is that there isn't actually any margin of improvement with a lot of the stuff you've mentioned- for example, all the ethernet tweakery.
Nobody, not even the manufacturers of "audiophile" network switches/cables has ever demonstrated any effect on the output of a DAC downstream from the "upgraded" item. Until they do that, you can safely ignore all of it...
Any feedback or thoughts on the upcoming upgrades are more than welcome!
Looks to me like you are concentrating on non issues but the good news is that you found the right place to learn what matters and what does not.
For the networking portion, your margin of improvement is nil as far as the transmitted audio data are concerned. You can have noise on an ethernet transmission, but unless it causes a bit error, it doesn't change the data being delivered. If an error causes a frame to be discarded, TCP provides retransmission of the missing data. Net result: removing noise from the ethernet signal does not somehow produce “better” audio data at the endpoint, the data delivered to it are the same regardless of whether noise was suppressed or not.
In the real networking world, eye diagrams are used to analyze ethernet signal integrity and determine whether the physical layer signal has enough margin. If the eye begins to close, you have a signal integrity problem that can produce bit errors, discarded frames and retransmissions. Until you reach that point, making an already compliant eye diagram “prettier” doesn't somehow make the successfully recovered bits better.
The thing is most of what you are planning is very expensive or extortionate for no audible improvement, whereas you can get quite marked improvement in sound for free by attending to the room - as long as you have freedom to do so, most people have to live in their listening room and have family so the freedom to get things optimised for "free" may not be feasible, and spending money can be fun if you have loads to waste ;).
My configuration is:
AT&T Fiber modem (1 Cat6) ➔ Netgear unmanaged switch (4 Cat6) ➔ Roon Nucleus, 2 X NAS, and also ➔ a second Netgear unmanaged switch (2 Cat6) ➔ L & R D&D 8Cs. Nothing else needed and it sounds perfect.
... and spending money can be fun if you have loads to waste ;).
And I'm very good at spending lots of money... just not on unnecessary network gear.
I just read through the list and it's too complicated for me. I have had 8Cs since 2019ish. Biggest improvement since buying is adding the trinnov altitude processor and properly integrating subs.
bro is just buying things to buy... Sigh, why will we never move on from BS beliefs in this space.
they are not even micro-level, which is great news--you don't have to waste money and effort :)
Congrats on the 6Cs btw! (I have the 8Cs and love them)
Isn't that a bit early? You just met him
It is. But it’s like meeting someone who has so much talk about his great skills as a painter, you just wanna ask: show me one of your paintings.
After all that snobbish talk about expensive network gear and other hifi voodoo, I like to see that room.
[System Showcase] Ultra-High-End Roon & Dutch & Dutch 8C Reference Configuration
Hi everyone,
I wanted to share the current state and upcoming roadmap of my reference audio system. The entire setup is built around active digital crossover architecture, with every single link in the signal, power, grounding, and mechanical isolation chains meticulously optimized for ultra-high-end standards.
1. Digital Signal Topology & Master Clock Architecture
The digital front-end utilizes a cascaded isolation approach designed to eliminate common-mode network noise, cross-talk, and phase noise before the signal hits the DSP stage.
[Modem] ➔ (CAT6) ➔ [SOtM Iso Cat7 Filter] ➔ (SOtM Cat6 SE) ➔ [LHY Audio EFI] ➔ (DM Connect) ➔ [Silent Angel NX Switch]
┌───────────────────────[Silent Angel Genesis GX Clock] (50Ω Tubulus) ────────┼────┘ │
[Silent Angel Rhein Z1 Plus] ◄─── (Platinum Starlight 10) [Port 5] [Port 6]
(Roon Core) │ │
(SOtM Cat7SE) (SOtM Cat7SE)
[SR Powercell] [SR Powercell]
[D&D 8C Left] [D&D 8C Right]
  • Network Ingress & Isolation: The long CAT6 run from the main router enters a SOtM Audio Iso Cat7 LAN filter to suppress high-frequency EMI. From there, a dedicated SOtM dCBL-CAT6 Special Edition cable feeds the linear power supply-driven LHY Audio EFI active network isolator.
  • Switch & Core Routing: The pristine ethernet stream leaves the LHY EFI via a Silent Angel DM Connect Ethernet cable into Port 1 of the Silent Angel NX Audiophile Switch. Port 8 of the NX Switch feeds the Silent Angel Rhein Z1 Plus (Roon Core) via a silver-conductor Wireworld Platinum Starlight 10 Twinax Ethernet cable.
  • Master Clock Synchronization: To minimize phase noise and sub-harmonic jitter, a Silent Angel Genesis GX Word Clock serves as the central master clock. It synchronizes both the Rhein Z1 Plus and the NX Switch via ultra-stable 50-ohm Tubulus Ximius BNC Clock Cables, lock-stepping the network packet timing.
  • Endpoint Termination: From the optimized Ports 5 and 6 of the NX Switch, two factory-custom, single-filtered 3m SOtM dCBL-Cat7 Special Edition cables deliver the digital stream directly to the integrated DSP inputs of the Dutch & Dutch 8C active loudspeakers.
2. Power Distribution & Active Grounding Topology
A true star-grounding scheme combined with dedicated power filtration ensures a virtually non-existent noise floor and unrestricted macro-dynamics.
  • AC Mains Infrastructure: A dedicated phase is pulled directly from the main breaker panel through an audiophile-grade fuse, running via Oyaide bulk cable and Schuco outlets into a Furutech E-TP 80 ES NCF (Nano Crystal² Formula) power distributor. The entire system is fed from this single point.
  • Linear Power Supplies & Digital Stack: The Silent Angel digital stack (Z1 Plus, NX, GX) is energized by the Silent Angel FX Linear Power Supply, which has been upgraded with a Synergistic Research PINK (5x20mm) fuse. The FX LPS is linked to the Furutech NCF distributor via a Synergistic Research Atmosphere SX-EXCITE power cord. DC power delivery between the units relies on Silent Angel Bastei Snowy White (0.5m) cables. The LHY Audio EFI is powered independently by a Furutech FP-3TS762 power cable terminated with FI-11 N1(G) / FI-E11-N1(G) plugs.
  • Loudspeaker Power Conditioning: The Dutch & Dutch 8C internal amplifiers are upgraded with Hifi Tuning Supreme³ (5x20mm) fuses. They are fed via two 3m Wireworld Silver Electra 10 power cords, conditioned locally by inline Synergistic Research Powercell One Conditioners.
  • Centralized Active Grounding: To eliminate stray chassis currents and ground loop mud, a Synergistic Research Active SX Ground Block acts as the central star-ground drainage point. Utilizing 1-meter Synergistic Research Foundation Ground Cables, it grounds the Silent Angel FX, NX, and GX units, alongside the Dutch & Dutch 8C backplanes via the Powercell One filters.
3. Structural Mechanical Decoupling & Room Acoustics
Katatropic and resonance-damping regimes are applied at every physical contact point to eliminate microphonic coupling in the electronics and energy storage in the stands.
[Silent Angel Z1 Plus] [LHY Audio EFI]
│ (4x Bassocontinuo Level 2) │ (3x Silent Angel S28 Shock Mounts)
│ Dual-Layer Corian Platform │
│ SOLIDTECH ROS 1 REGULAR (Sand-Filled Rack) │
│ Solidtech Disc of Silence Isolation │
│ 4x ISOLATOR SUPPORT Isolator Feet │
│ Hun Audio Steel-Ball Isolation Discs │
  • The Extreme Stack Isolation: The digital electronics are stacked on a high-mass, dual-layer Corian platform. The Silent Angel Z1 Plus is decoupled using 4x Bassocontinuo Ultra Feet Level 2 kinetic energy absorbers, while the LHY Audio EFI sits on 3x Silent Angel S28 Stainless Steel Shock Mounts.
  • Rack & Sub-Chassis Decoupling: The Corian platform rests on a sand-filled Solidtech ROS 1 Regular Hi-Fi Rack. The rack frame itself is mechanically decoupled from the floor via Solidtech Disc of Silence spring-loaded systems sitting on 4x Isolator Support feet. The spiked feet of the rack finally rest on 4x steel-ball Hun Audio vibration isolation discs.
  • Loudspeaker Interface & Cable Management: The Dutch & Dutch 8C monitors are mounted on Dynaudio Stand 20s, heavy-filled with an optimized ratio of silica sand and lead shot to suppress internal standing waves. The stands sit on IsoAcoustics Gaia II decoupling feet. To prevent airborne vibrations from affecting the dielectrics of the heavy 3m Wireworld power cords and thick SOtM Cat7SE cables, they are systematically floated off the floor using Cable Elevators.
  • Acoustic Calibration: The room response has been strictly mapped via REW (Room EQ Wizard). Geometry, distance mapping, millimetric Toe-in adjustments, and target-curve DSP integration were finalized based on impulse response and decay waterfall measurements.
4. Upcoming Upgrades & Roadmap
To push the envelope of this digital front-end even further, the next steps are planned as follows:
  1. Phase I - Dedicated Network Bridge: I will be introducing a Silent Angel ZX Transport into the stack over Ethernet. It will take over endpoint responsibilities, leaving the Z1 Plus to act solely as a heavy-lifting Roon Core. The ZX Transport will lock to the 3rd isolated output of the Genesis GX Clock via an additional 50-ohm Tubulus Ximius BNC line for full Triple-Clocking.
  2. Phase II - Monitor Fuse Overhaul: The fuses on the Dutch & Dutch 8Cs will be upgraded to the state-of-the-art Synergistic Research MASTER (5x20mm) fuses to unlock further transient speed and micro-dynamic expression.
  3. Phase III - Active EM/RFI Conditioning: Finally, I plan to deploy a Synergistic Research Tranquility Pod Carbon directly between the Z1 Plus Core and the new ZX Transport to capture and neutralize dikey-axis inductive cross-talk. Alternatively, I may completely swap out the dual-layer Corian platform for a full-sized Synergistic Research Tranquility Base Carbon active electromagnetic isolation platform.
Thanks for reading! I will keep this thread updated as the ZX Transport arrives and the active EM conditioning is deployed.
Like others have said: rather create a master plan in meticulously figuring out how the room interacts with the speaker and then treat the room, change speaker position and use room correction until you have the best result for the room. Then you will have reference sound (for that room).
Decided to remove the configuration layout as the discussion is moving away from the synergy of the setup and into textbook debates. I am thoroughly enjoying my system and the incredible engineering of the Dutch & Dutch 8Cs. Happy listening to everyone!
Any one have a set of the 6C’s on the way?
I am really curious about what the 6S floor will have on tap regarding any floor/ceiling reflections or interference (how ever you want to describe this pesky problem) - remedies such as null steering or however the Kii BXT avoids those issues.
Or just any updates in general. I understand the choice to avoid giving out details until units are about ready to ship though.
Agree that some news about 6S would perhaps guide some purchasing plans people are putting together :)
