Why even ask. This is all speculation.
I think you and many members overestimate their listening skills.
I would really enjoy hearing about the results (especially room decay below 200 Hz). I like the idea of arrayed subwoofers for rooms whenever it is possible. Of course measurements (at least for me) tell the whole story.well, in a few weeks i go to the Zurich region (Swiss) to install an 40k€ dsp (Trinitov Altitude32 with some options) in a house of of a billionaire who wants to try the Waveforming technique. We will also install 20 18" subwoofers powered by 8 Powersoft amplifiers with in total about 100kw to make this work. Mains are JBL M2 and this is a stereo system (he has a full equiped Dolby certified home theater also) in his music room that is quiet big (8x15x5m). I'm the project manager (and youth friend of the billionaire), the config won't be done by myself but by specialists and i can say this project costs more than a million €'s (also the electric power system needs adaptation).
There are billionaires who care about audio and sound quality, but they don't have time to quarrel arround fora like here, they got staff for that. And they won't show of their system on public, because they don't care about their opinion...
So he basically want to get a barotrauma experience and liquefy his internal organs or is it maybe he just planned to make his house levitate? Or being a billionaire he just wants to train for a rocket launch I dunno really, these numbers are out of this world!We will also install 20 18" subwoofers
If it is the application that I have seen before, half of those subs will be used to cancel much of the modal effects of the room.So he basically want to get a barotrauma experience and liquefy his internal organs or is it maybe he just planned to make his house levitate? Or being a billionaire he just wants to train for a rocket launch I dunno really, these numbers are out of this world!
Definitely an interesting project! I'd also be pretty much interested in comprehensive measurements (RT60 decay graphs etc. from around the listening area) of with and without the Trinnov "active noise cancelling" in place and a sketch of where the subwoofers had to be placed respectively. (Surely I also wouldn't want my system go public.) I can only imagine how a room would look like with let's say 20x JBL SUB18 around. They'd need to be placed all over the space at their respectively best locations for optimum performance. -- And still there would be channels left to expand for proper Dolby Atmos Music if desired.I would really enjoy hearing about the results (especially room decay below 200 Hz). I like the idea of arrayed subwoofers for rooms whenever it is possible. Of course measurements (at least for me) tell the whole story.
This is not correct. The cardioid pattern is not created by the rear woofers, it is created by the side vents.It requires high output from the woofers to create the cardioid radiation pattern.
For clarification: That is true in this case. But it can be done using the rear (or side) woofers if you should choose too. But it is better using the vented slots. But you are absolutely correct about the Dutch and Dutch. It seems to be the most popular way of doing it.This is not correct. The cardioid pattern is not created by the rear woofers, it is created by the side vents.
It's needed for the Trinitov waveforming, a way of making the bass soud good in a room, with a lot of cancelletions. And headroom is also key, to get undistorted bass to about 20Hz. And it's not that it's a small space to fill. And his moto for this was "overkill" (aka i never want to hear that the system is to weak to do this).So he basically want to get a barotrauma experience and liquefy his internal organs or is it maybe he just planned to make his house levitate? Or being a billionaire he just wants to train for a rocket launch I dunno really, these numbers are out of this world!
How was the choice of the M2's made?It's needed for the Trinitov waveforming, a way of making the bass soud good in a room, with a lot of cancelletions. And headroom is also key, to get undistorted bass to about 20Hz. And it's not that it's a small space to fill. And his moto for this was "overkill" (aka i never want to hear that the system is to weak to do this).
But running this as front sub full force, is indeed crazy. But that is not the goal. And the 100kW is peak power, (real life) RMS will be more like 40kW knowing those amps...
And it is actually quite easy to see the SPL loss of the midwoofer in the nearfield measurements. Considering that in the far field the midwoofer will be 6dB below summing level at 100Hz and same level as the subwoofers, we see that the mid-woofer output is approximately 6dB higher than it would be without cardioid losses. As the subwoofer nearfield response seems a bit high in level, cardioid loss may even be somewhat higher (e.g. 8dB at 100Hz).It requires high output from the woofers to create the cardioid radiation pattern. These D&D 8C measurements are from Erin's Audio Corner.
Compared to Neumann KH150. (Note that -20 dB = 10%, -30 dB = 3.2%, -40 dB = 1%)
It's certainly true that bass distortion is a lot less audible due to how our hearing works but maybe there are different factors involved which smear the impression.[...] This raises questions about audibility of distortion at high SPL. Considering that 100dB SPL (pink noise with 12dB crest factor and HP around 60Hz according IEC-268-1, A-weighted) is the regulatory limit for headphones in the EU, we should reming ourself that 96dB is quite high level. Nevertheless, considering the cost of the speaker they should use better drivers imho.
Yes, that's exactly the reason why HARMAN introduced the JBL SUB18 for use alongside the M2. And since the woofer works up to 800 Hz in the M2, that would also significantly improve midrange performance!The M2 has a lot of headroom, so in a smaller space on low volume the woofer does not distort. But if you play loud in a big room, the distortion also comes. That's why in bigger rooms using seperate subs with the M2 highpassed at 80Hz is needed to have low bass distortion.
Are the graphs using different values? The one for the 8c's are showing the distortion in db's while the Neumann's are showing the value in distrotion percentage. It appears to be apples and oranges to me, or am I wrong? Seriously asking here...It requires high output from the woofers to create the cardioid radiation pattern. These D&D 8C measurements are from Erin's Audio Corner.
It's more like comparing red and green apples.Are the graphs using different values? The one for the 8c's are showing the distortion in db's while the Neumann's are showing the value in distrotion percentage. It appears to be apples and oranges to me, or am I wrong? Seriously asking here...
dB and percents are just different ways of expressing a ratio, and we can easily convert one to the other. dB uses logarithmic scale, so easier to see the smaller values. For example, if we plot percentage using a linear vertical scale of 0% to 100%, you can hardly distinguish 0.1% from 0.01% when looking at the plot, because both are very close to the bottom. With dB scale, 0.1% is -60 dB and 0.01% is -80 dB and there is good separation between the 2 numbers if you plot using a vertical scale of, for example, -120 dB to 0 dB.Are the graphs using different values? The one for the 8c's are showing the distortion in db's while the Neumann's are showing the value in distrotion percentage. It appears to be apples and oranges to me, or am I wrong? Seriously asking here...
So, if I used the calculator correctly - the Dutch&Dutch has approximately 1% THD at 50hz @86db /3.98% at 96db.....compared to 0.97% @86db /2.8% @96db for the KH150 (both at 50hz)It's more like comparing red and green apples.
Granted, you need a minimum of imagination but he actually mentioned the correct conversion rates in the same post you just quoted:
