Dutch & Dutch 15C Discussion
You can, ameliorate the effects of room modes easily enough particularly with contemporary actives because they have built-in equalisation.
Only in one spot though. You need distributed subs to cover more of a room
Considering how the drivers are spread and the crossover point, I do think that this speaker is designed to be listened too at at least 3 m away, though 4 m would be considered safer. That's gut feeling, not proper calculation. At those distances, the vertical listening window is probably okay for a variety of couches, sofas, and listeners' tallness.
Listened briefly to these speakers today, and found it extremely joyful. They are very dynamic, with a punchy deep bass, slightly elevated treble, however, always on the pleasant side. Not the most neutral presentation, but fun.
I owned the 8C for a while and there is no doubt in my mind the cardioid made a difference in sound quality. They have the most soundstage depth and detail of any speakers I've heard. The cardioid gave the speakers the ability to basically eliminate SBIR and the effect was like the wall in front of them wasn't there.
The thing with these larger speakers is that SBIR isn't as much of an issue with such a wide baffle, which already controls backwards radiation of sound waves into lower frequencies. I don't see the benefit of sacrificing efficiency just to get maybe an octave of directivity control.
Moreover, that control could be achieved by simply using the rear drivers to make the cardioid. Live sound systems do the same thing with subwoofers and don't sacrifice efficiency because the physical separate of the drivers allows the constructive and destructive interference to work optimally for the wavelengths in use. The cardioid design of the 8C and 15C works by creating destructive interference in every direction, with more destructive interference behind the speaker than in front. You lose output from the forward direction of the driver, but you lose even more output in the rear direction, so the net effect is directivity control.
Didn't fully realised how big they were.
It appears you got rid of the 8c. What replaced them and why?
seems a bit haphazard to have such massive speakers on stands, could cause serious damage/injury if accidentally pushed over. surely for the price they should lock into the stand which should also be heavily weighted (anchored to the floor?) in some way.
Or just design darn floorstanders. Makes zero sense to me to have such a massive stand mount.
Well... makes no sense until they release the sub module that these sit on, effectively making them floor standers with enough deep bass to crack the foundation of most houses.
Reactions: MKR
With no disrespect to D&D - maybe the goal was mostly to generate buzz. Which it did.
