tineared
Sure. I'll try and tell my wife that's the domestic version. Oh, by the way, they cost as much as your last car...
A Non‑Environment Room is a control room where the engineer should hear only the direct sound from the loudspeakers, with virtually no coloration from the room itself. The goal isn’t just to reduce reflections — it’s to make the room disappear as an acoustic factor. As Newell often puts it : the room should not exist acoustically.
The side walls, ceiling, and rear wall are almost entirely absorbent and the target is an extremely low RT60, often below 150 ms across the entire spectrum, including the low end. Absorption depth is substantial, typically 60–100 cm or more and will use menbranes, to target the deep lows. The wall behind the monitors is hard, massive, and reflective.
The loudspeakers are flush‑mounted into this wall to eliminate diffraction, suppress SBIR, maximize time‑domain coherence.
Consequences are that direct sound overwhelmingly dominates, early reflections are virtually nonexistent (desk is the main exception), the diffuse field is extremely weak.
You got an extreme precision, a reduced listening fatigue, and a excellent translation to other systems. It is not a “dead room” in the 1970s sense because you have psycho-acoustics to help your mind to be at ease in the room (reflective floor, diffusion above and back listening point to complete the frontwall.
Newell’s premise is simple : Modern, well‑designed loudspeakers are far more reliable than rooms. So if you want a stable reference, you remove the room from the equation as much as possible. This is the opposite of an RFZ (Reflection‑Free Zone) design, which intentionally preserves a stronger diffuse field.
I'm familiar with nonenvironment rooms. I think you missed my point.Careful, i think there are currently some excessive generalizations being made about Floyd Toole’s statements on acoustic treatment.
The way I understand Toole’s point (though I’ve only watched his lectures and haven’t read his book yet) is that if you just put up relatively thin porous acoustic panels—around 10 cm or less—you end up with early reflections that have lost their high frequencies but still contain low‑frequency energy, which can actually make the acoustic problem you were trying to fix even worse. But no serious acoustician work that way for quite a long time now.
The misconception become obvious when i talk about a non environnement design (A concept published by Philip Newell for the AES in 2017 for last edition), and you answer about a Reflexion Free Zone wich is an older concept developped mainly by d'Antonio et Cooper in the Eighties.
So yes, I agree: having the best loudspeakers you can get is important, and controlled off‑axis directivity, along with good frequency and phase response, definitely makes your life easier. But I don’t see any scenario where you can achieve a flat 150 ms RT from 20 Hz to 20 kHz in a “domestic” room — even with something as impressive as the DD 15C, a large space, and well‑designed geometry and modal distribution. The level of precision that a truly great acoustic design can provide simply isn’t achievable yet through loudspeaker design, DSP, or multisub strategies alone. (Maybe that will change one day with active bass trapping.)
So yes, saying that great speakers with well‑controlled directivity and DSP correction are the most cost‑efficient solution for domestic listening is totally fair. But if you want a genuinely state‑of‑the‑art system — room + speakers — and you have a budget around €100,000, then as far as I know, nothing matches the level of sonic accuracy you get from a properly designed room built around flush‑mounted, top‑tier monitors.
"Consequences are that direct sound overwhelmingly dominates, early reflections are virtually nonexistent (desk is the main exception),"Thank you for taking the time to succinctly describe the why and the what and the how of a "non-environment room".
You need your controls under your fingers to work efficiently, il would be quite a pain in the butt to do constant back and forth between your main work position and listening position"Consequences are that direct sound overwhelmingly dominates, early reflections are virtually nonexistent (desk is the main exception),"
Been in a couple studios and yes all have the console desk right smack dab in the listening area causing who knows what myriad of reflections. Why not place the console against the back wall furthest from the speaker, make adjustments and simply swivel around to listen. You certainly don't need to stare at the speakers to make adjustments. Am I missing something?
CJH
https://www.audiosciencereview.com/...eptual-effects-of-room-reflections.13/page-29Listening to speakers without not even the smallest radiation from the room, is listening in "an anechoic room" or "chambre sourde" (deaf chamber) in french.
I don't konw what's a "no environement room" is ? There are always some room effects, as tiny and well controoled could they be,
[SIZE=3]Indeed, this concept needs more explanations.[/SIZE]
For me it looks like the SB Audience ROSSO-15W400, but it's most probally an OEM design by one of the OEM builders in Europe tailored to the wishes of the designer/company. The front woofer is also different (probally a midwoofer) than those on the back (probally subwoofers) of the 15C on first sight.It's not atc-like other than the paper diaphragm. The surround is totally different, more like a high output pro driver.
I'm also kind of lost lolI don't know what anyone is talking about anymore.
We're stiil waiting on your current and future room size and SPL requirements.I'm also kind of lost lol
Uh, we also need to know if he now plans to construct a “non-environment” room.We're stiil waiting on your current and future room size and SPL requirements.![]()
Also it was Tom Hidley who invented the nonenvironment "hemianechoic" room (because the floor is reflective). In early iterations the floor was also absorptive but the overall effect was considered too unnatural.
Just as well ‘cos if one of those speakers fell on you, you’d be De&D…The 15c stands weights around 55kg.
They are very sturdy and secure.
You would have to apply a lot of pressure to tip the 15c over.
Unfortunately, the amps got stuck in customs.just curious if the 15c was just being a static display? or it actually on demo at the recent NAMM 2026?
Anyone here heard it and how was the impression comparing to 8C?
that's very unfortunate, was expecting impression on the 15c from people that heard it.Unfortunately, the amps got stuck in customs.
Amps and smarts will be external. Not built in as the 8c and 6c.
What's the official price? ThanksUnfortunately, the amps got stuck in customs.
Time is money, so yes you doYou certainly don't need to stare at the speakers to make adjustments.
