thanks
it not identify support dolby atmos
check this one, support dolby atmos
Thanks for sharing. If you buy one, would you mind posting pictures of the insides?thanks
So unless I'm missing something, it won't give any benefits over the extractor mentioned in the first post.The Navceker HDMI-compatible Switch supports LPCM 7.1CH, Dolby True-HD, DTS-HD, AC 3, DTS, DSD, Dolby Digital Plus, and Dolby Atmos audio formats, but cannot decode these audio formats
Hi, would u mind upload some pictures of your setup of the two boards?No, not disconnecting anything, I even left the resistors in place and simply soldered the wires to them.
Sorry, I didn't make any photos back then, and now everything's assembled, so there is not much to see. But connecting the lanes is quite straightforward, as long as you have a datasheet for one of the chips (was linked somewhere in this thread) and a digital multimeter to test the connections.Hi, would u mind upload some pictures of your setup of the two boards?
Would regular HDMI multichannel audio suffice? Much easier than HDMI earc source.I'd like to DIY an hdmi earc source from a computer.
Well, @stigger managed to hack the board in post #1 and bring the multichannel signal to a raspberry pi successfully. I have not found any other eARC device that exposes the i2s pins in a header and the evaluation boards remain expensive, so probably something like the one in post #1 is still your best option.no more update on this ?
That means eARC RX controls what the TX can send. It's logical, technically correct, but it means IMO a proper eARC (or ARC) support requires being able to control the eARC receiver - what audio capabilities the eARC RX sends in the capabilities data structure. Maybe some hard-coded default (8ch, ...) is being used in the standalone eARC receivers.The eARC TX shall not send audio other than Basic Audio unless the eARC Capabilities Data Structure indicates support
of other audio formats and sample rates. The eARC TX shall only send Basic Audio or audio that the eARC RX indicates
it supports.
