Audiomaniac3
- Joined
- Nov 8, 2024
- Messages
- 100
- Likes
- 61
Hello everyone,in this video:
I’ve got a pretty interesting amplifier to review.
The AAM8 model boasts highly impressive specifications.
Single board houses two TPA3255 chips, each operating in PBTL mode, which allows it to deliver 300W RMS of output power per channel.
The board is very well-assembled, and it features swappable operational amplifiers.
Operating from 32V to 48V DC with built-in undervoltage and overvoltage protection,it makes choosing a suitable power supply incredibly easy.
The amplifier arrived in a plastic case along with a set of cables for connecting the speakers and the power supply.
In addition to the standard AUX input,you can feed a balanced differential signal to the amplifier by setting a jumper.
To do this,I connected an extra board that allows for convenient XLR cable hookups.
With an SNR of 117dB,the amplifier has a noise floor of ~36 microvolts for the balanced input and ~48 microvolts for the single-ended input.
This means absolutely zero hiss,even on the most sensitive speakers.
For heat dissipation,the amplifier features smart cooling.
The fan kicks in automatically only as needed,so if you're listening to music at low volumes,the fan won't even turn on.
The amplifier maintains extremely low output distortion at both low and high volumes:
200W RMS at 0.1% distortion (6Ω)
250W RMS at 0.1% distortion (4Ω)
I connected the Fosi DS1 via the 4.4mm balanced output.
The first thing I noticed was the massive output volume,even with my 32V power supply.
I actually had to lower the volume just to listen comfortably,it's a good thing the DAC itself has dedicated volume buttons.
My subjective impressions.
The sound is incredibly clean.Over the balanced connection,channel crosstalk is completely non-existent which makes the soundstage feel exceptionally wide.
This is great DIY board with exceptional specs.
More information about AAM8:
store.sure-electronics.com
XLR board:
WONDOM OFFICIAL SHOP - Bluetooth Amplifier Board - Sure Electronics - BCPB - 18650 charger - T-AMP - Volume Control
Sure Electronics is a professional audio amplifier supplier that provides electronics hobbyists and business partners the middleware which can help reduce customers' development difficulties and save their precious time-to-market by making the products directly released in the market.
XLR board:
