Dual sub suggestion
PaulF2020
Hi Folks,
I had dual Rel T5s, which worked great, however one died so I need to find new options.
1. I can try to find another T5, but they're discontinued so it is quite tricky to find at a right price.
2. I can just sell one REL I have and get a 2 new subs.
So, if I go that route, what subs could you suggest, I have few requirements:
1. should be sealed/passive radiator
2. 8 or 10in, I don't need to go super low, my current T5 has following measurements. I even considered t-zeros, which are reasonably priced, but my worry is that they might be too light.
3. reasonably compact, ideally around t5 size
4. price, should be a budget one, ideally under 300GBP (I'm in the UK).
It will be used with REW and F6B speakers.
It is very difficult to find measurements for subs it seems, not sure why.
The money limit as no hair left said above is a bit low.
All your needs and more ( peq ) are in svs sb 1000 pro but that costs about 500 pounds or so.
It is measured somewhere online i read the review of bot sb and pb varients.
