daniboun
Hi amigos,
Here a short review about the brand new TPA3221 :
Setup :
DAC : Gustard X16
Amp 1 : Hypex NC252MP
Amp 3 : Dual TPA3221 / OPA1652 (stock PSU 15V / 7a + FX Audio 24V / 4A PSU)
Amp 4 : HanZao TPA3255 / OPA1692 + Shui Yuan OPA1656
Playlist : HD audio via LDAC BT
Indroduction :
This dual TPA3221 is really small about 134x59x90mm, compared to the Aiyima A04 for example : 150X92x40mm.
The case is a full alu black enclosure, it's still pretty basic but rather robust. The connectors are pretty good and seem solid.
Under the Case, we therefore discover two distinct TPA3221 boards with a really surprising PCB. I would say the components seem to be of good quality
We see some Samsung FC power caps 35V@ 1800uf / Evox Film caps / Elna Audio caps / OPA1656.
The spec of the TPA3221 are available here otherwise:
TPA3221 data sheet, product information and support | TI.com).
I did not measure the amp but in Living room (30m²) with my 2.5 floor speakers, the power is more than enough to drive my speakers under 8 ohms with a more than comfortable volume even with the stock PSU.
I made a 1h30 listening test yesterday VS my other amps and here are my observations with my favorite Playlist :
Bass :
Complex song : Downtown (Yellowjackets & WDR) : The bass is very well maintained, it is precise and it does not drool. Blindfolded, it is very difficult to perceive a difference in the human ear vs my Hypex NC252. Although I'm convinced the Hypex is better on paper. With the 24V PSU we gain slightly in power but it's also really good with the stock PSU. I hope that future reviews will confirm my opinion but the bass is tight and very present despite its small size)
Medium :
Audiophila Master CD18 : Voices stand out very well from the mix, they are well put forward. I found a very silky side in the mids, the amp is closer to the TPA3255 Hanzao / OPA1692 than to the Shui Huan OPA1656. I find my Hypex NC252 better in this register, however. Either way, I didn't find listening tiring.I let myself be carried away by the softness of the amp without any problem.
Trebles :
Being a drummer, I am particularly sensitive to this point. I used to collect cymbals and have a ticklish ear lol ) With the Drum Collections HD files : I found it to be very good, the rides are subtle, the crashes stand out without aggressiveness (I use a ribbon tweeter). Compared to my Hypex NC252, frankly it's quite impressive! We tickle his performance level. Overall very good behavior in the treble.
Soundstage :
Impressive! I have always found that dual mono configurations were more interesting on this point.
Audiophila Master CD 17 : Everything is well detached, the instruments are well distributed.
We find the signature of the TPA chips, it's as good as my TPA3255. I have always liked the TPA325X regarding the Soundstage and I am not disappointed here.
Negative points :
- The volume is reversed, we increase by going to the left) (can be corrected easily anyway)
- I would have preferred a Power Switch on the front for accessibility reasons
- With the 24V PSU, a tiny Pop sound when Switching ON only. Nothing to complain with the 15V.
- A strange behavior that I also observed: the start sequence is important here: I have to turn on my DAC before the amp otherwise I have a marked pop.
- No DIP8 op amps socket but OPA1652 seem really good !
Conclusion :
I paid the amp 56 euros ! It is a little bomb for this price : it is a small / compact and sounds very good. He does not blush in front of my Hypex and he will convince most ears. It lacks a bit of power it's true! But for a listening at moderate volume it is enough believe me! It is not at the level of my Purifi that is about 20X more expensive)))
At this price you will not take any risks! I think this little dual Mono TPA3221 is a great choice for less fortunate wallets.
VIDEO :
https://streamable.com/yy8p0g
https://streamable.com/vekq1h
Setup :
DAC : Gustard X16
Indroduction :
Bass :
Medium :
Trebles :
Soundstage :
Negative points :
Conclusion :
VIDEO :
