320W actually, yes. But the LOF225 PSUs used in the DA-9/AO200 amps do not reach 300W, but only 225W.
This may be because those op-amps in difference to other D-Class amps are not being used right before speaker-out (for those are included within the chip-IC), but before the Merus IC as far as I see through it. Since they're only used to pass-through a low-power current (+gain information) which is being amplified by other Merus internal op-amps again afterward, they're not that important since those NJRC controllers are very low THD anyways, much lower than the amp-stage. Please correct if I'm wrong.
@Moosi you are correct about the power-supply, I double checked and no doubt you did too.
The DA-9 and the A0200 has slightly different op-amp configurations.
I had both amps. my A0200 is currently on it's merry way back to china from Japan via Aoshida Japan, they will take receipt of it tomorrow, they will fedex me a new amp with the display reading bluetooth instead of bluetoot! Zero other functional changes.
There is a 1678 and an ST072c. I suspect that since the DA-9 has only one of the 072c's it's for the single sub output, and the 1678 is a cheating method for creating what I call a semi-balanced output. I secretly (don't tell SMSL, or Aoshida Japan) changed the 1678's to 1612's It sounded worse by a significant margin. I tried another set of op-amps and everything was soldered correctly with full contact, but I got popping noises. that was the 1656 a bit of a hidden gem.
Yes, you are correct there are miniaturised op-amps within the chipset that we have no access to. There is no reason in my mind that they would manufacturer a chipset that is fundamentally wrong. The NJRC controller is a bit of a gripe for me as I know that there is a step up from the model they used.
I DO NOT believe you are wrong. I also don't think that we know all that there is to know about exactly what tricks that SMSL and Aoshida/SMSL used in the jumping/wiring of the chips/+programming.
There is no physical space for any other PSU in either amplifier, The case is literally full in both cases.
Let me ask you what amplifier currently on the market has the same performance as the SMSL duo, assuming they are problem free?
Aoshida is far more on top of it when it comes to customer service, at least Aoshida Hi-Fi Japan is.
I think that there is a slight level of expectation that is unreasonably being placed on the amplifiers.
Also remember that Infineon bought out International Rectifier Company from the USA. These/those people knew what they were doing maybe not on the financial end since they went under, but they manufactured some seriously high performance chips.
I'd like to set the record absolutely straight as I have said on multiple occasions. We have only the specs that are provided by SMSL/Aoshida. No 2nd or 3rd party measurements. I think it's best to wait until we get some measurements and see how it coincides with user ratings and opinions in the "real-world". If you have one, then you know, if you don't then single thing other than what is published which is seemingly not exactly how the chips are programmed or wired becomes speculation. And I am not accusing you of either. We just need a 2nd/3rd party review. That would settle a lot of the speculation. The A0200 is the best iteration I have seen thus far. I used to own a DA-8s and I ran it 24/7 with a nominal 2.7ohm load. The DA-9 and A0200 also runs at a 2.7 ohm load all day everyday. I think that's pretty stable myself. And I am notoriously hard on my equipment.
Meanwhile they're both new amplifiers. Expect them to be in production for 2 year, maybe 3. With Class-D there will always be a newer, better, greater version in less than a model year. This is inevitable.
I do agree with you however. No question in my mind, you have my agreement. Cost/space. The primary concern. Also safe voltages and current for the chips without running them at 100%. Also a lot of the specs are WITHOUT heatsinks. Both amplifiers use aluminium blocks and the chassis as a cooling system. And frankly replace the white thermal grease for a paste with a much higher rating. The standard white grease is in the super low 2's for heat rejection/absorption.
