DSJR
I LOVE the 1229 with a passion, but it's one of Dual's more complex machines needing very careful alignment if stripped down for service and certain rubber parts in the tonearm height assembly MUST be replaced before proper use, as if not and the arm-height lever is used, one risks breaking off two little 'ears' on what's known as the dearing ring which is fitted to the bottom of the outer tonearm gimbal. This will render the deck unusable until it's fixed and currently, I'm not sure Shapeways exist to sell you a replacement - look on Vinyl Engine for comments by Dualcan (Klaus) about it, as he knows more about these decks than almost anyone else. His Dualcan tumblr site is a must for servicing information, as he uses his official Dual service experience to strip them to the last screw and clip and then rebuild them to spec. He's helped me no end over the years. Other later model fully auto Duals may be a better bet if you've not got into vinyl auto deck servicing as they're much simpler underneath.I have. I'll try to trade it in for a second hand 1229.
PS: looks like there is more to budget turntables. Fortunately, everyone seems to recommend not to worry too much about it and just get vinyls.
I lent my 1229 out and very sadly subsequently lost it, so replaced in 1989 or so with a good used 701 which is still my main spinner today (yes, I have Lencos too in the 'stash'...). I was gifted a 1019 which is gorgeous with so slick controls, but not quite as quiet or capable overall, being a far earlier design.
(anal nonsense, but the 701 is playing 'Meadow of Infinity' by Peter Baumann and the 1019 is playing a nice copy of 'The Yes Album')
I totally forgot and Lini (and others?) reminded me
Does the entire unit have a tape record output? if so and the Klipsch master speaker has a volume control, i wonder if it's possible to use the Dual system that way and save some money? Styli for the Dual pickups can still be obtained (I very much doubt these ceramic pickups would be bad ones of their type). The main difference is more surface noise from records, but you usually get a very 'direct' sound to make up for it.Good luck.
P.S. If you wanted to try for a good used Dual deck, the simple auto-stop-n-lift 505 in various marques can be easily got for not much money and the later ones (505 - 3 onwards) often had nicer and more solid plinths, the Ortofom OM based pickup (and the deck as a whole) happily accepting an OM20 stylus which gives a more refined sound up top, which used to be cheap but isn't now, sadly.
