Good evening people,
Currently I'm using a RME ADI-2 DAC with DT1990's but I feel like it's time to upgrade my headphones. I have done some scouting around the internet and of course the forum for a set of cans I don't want to replace anymore after I bought them. So what would you guys choose to pair up with my ADI-2? I'm currently leaning towards the Sennheiser HD800s, but open for suggestions
Late response, sorry;
The HD 800s are cool and plenty of people love them. As someone who has had experience with both the 800s and the dt 1990s, I would caution considering it an upgrade. The 800s sound very similar to the 1990s with analytical pads. The main differences are:
1. A larger soundstage on the 800s.
2. Slightly less sharp sibilance but less air on the 800s
3. Significantly worse bass performance on the 800s.
I'd consider the 800s a side grade. They both have a competitive take on diffuse field tuning and have similar detail. I'd say the 800s has very slightly more detail in the mids and treble, but the 1990s completely destroy the 800s bass. The extension is a significant upgrade as this is a major weakness of the 800s. The soundstage is pretty great on 800s and the comfort is better in stock form. If you really like bright headphones (sounds like you do) I would consider the hifiman arya as it goes for similar money and has a better FR and overall performance. The build is worse than both the 800s and 1990 but it sounds better to me.
Take all this with a grain of salt. I daily drive empyreans and verites because my FR preferences are much warmer than I thought when I got into the hobby.
