Keith_W
I was not aware of that subtractive filter method, thank you. I will read that DIYAudio thread you linked and experiment a bit with it.
I suppose the use case of the DSPNexus is for a more advanced DSP user than MiniDSP. Audioweaver may be complex, but it is also very flexible. I would be very impressed if you can use it to coax a linear phase filter from a DSPNexus. Can't say the same about MiniDSP. I borrowed a MiniDSP for a few weeks and I was impressed by how simple it was to use. But ultimately I found it to be quite limiting.
FWIW, I am not opposed to DSPNexus as a concept, I just didn't know how it fits in the marketplace. Now I know. Maybe i'll buy a unit and play with it a bit. I know FIR filters, but I know a lot less about IIR's. They just seem so difficult to design. Certainly being able to achieve linear phase to 20kHz with no pre-ringing and minimal latency sounds very attractive. Also attractive is the challenge of learning to use AudioWeaver ...
