DSPi users (and prospects) projects discussions
The project for a 6-channel stereo amplifier for 3-way speakers is slowly moving forward.
The next stage of the project. The boards are assembled and working. The amplifier is currently driving speakers near the computer and undergoing numerous tests. Unfortunately, the two MA12070P chips on the left board operate in analog mode as MA12070. Therefore, I'm waiting for another parcel of chips to assemble the correct board. Then it will be assembled into the case. I'm planning to use a 1U ethernet switch case; they are very suitable for this project.
Big Knob possibilities
If people are looking for a remote, I posted this deloop project on here back in July. I didn't come back with much follow up, but I did put a ton of work into responsiveness and touch controls since I posted, so it's much snappier than the video in that thread. This knob is my daily driver at my desk (I work from home), and I've used it every day since posting that thread, and haven't experienced a single hiccup since my last code push back on Aug 8th, so I'm pretty confident in it's stability. I have it pointed at a Denon AVRX4800H with Dirac ART, and couldn't be happier with this little dial.
That said, no, it won't work with DSPi today, as there is no support for it. Since I'm not a DSPi user, I also don't have the hardware or interest to test it and do the integration. What I will tell you though is that I my specific style of Claude usage would make this trivial for anybody comfortable playing with hardware and poking at python with Claude to do the implementation. There is a .claude/CLAUDE.md file that drives an agent maintained KB that's baked into the repo's docs folder. Claude is instructed to maintain this KB in a specific style that basically lets it drive the whole project. It's been there from day one and has my entire project history and architecture. As such, using Claude on this project will give the agent deep context into the entire code base, how it works, how to add new support, and even a pretty deep understanding of the M5 dial end ESP32 and hardware within it.
If anybody does decide to take this on and add DSPi support, know I'm more than happy to accept well tested and functional PRs that align to the codebase, style, and architecture of what's already there. Using Claude intelligently should mostly guarantee this.
The project is almost complete. The case has been modified. Power supplies with active PFC have been installed. They consume sine-wave current and generate significantly less noise in audio frequencies of 100-1000 Hz. Integration of the data exchange protocol with the DSPi has been completed. Now I can receive any data and control the DSPi parameters from my controller. Minor flaws have been fixed. In particular, a supply voltage monitoring circuit was added using point-to-point wiring. After the power supply drops below 18 V, mute and disable signals are sent to the amplifiers to prevent loud sounds in the speakers when the power is disconnected. The front panel has been printed. The design is certainly budget-friendly, but it suits me. All that remains is to wait for the MA12070P chips from China and solder another amplifier board. I hope there will be no surprises with it :) .
