olds1959special
The benefits of an active crossover
The benefits of an active crossover in digital speakers.
DSP is a tool which can be used or abused.
Reading some of jj's work on room correction I tried using "ERB Smoothing" on the measurements before I created the correction filters in REW, previously I had used "Var smoothing". Of course this resulted in a much lighter and smoother correction filter which measured much less smooth than either the manual filters I created using Var smoothing in REW or what ever filters DIRAC DLBC cooks up. DIRAC by far measured the "smoothest" in room response but I preferred the "ERB smoothed" correction filters.
While it is now possible for almost anyone to get a MIC and make measurements of their system before and after correction I am not sure that is a great thing as it pushes companies like DIRAC and DIY filter makes to try to hammer their in room response as flat as possible which while it may look nice on the measurement graph may be suboptimal to listen to. Human's ability to "hear through the room" as well as humans hearing limitations, both of which are taken into account to some extent by ERB smoothing, needs to be considered when creating DSP filters as more is not always better.
Very interesting.... I was always worried about getting enough taps for LF accuracy and never thought that more taps had a downside beyond processing power limitation and latency.In analyzing filters' impulse responses, I've been finding that the degree of smoothing applied in attempting to clean up impulse, has been making less of a difference than the length of the FIR filter. It helps to use the shortest FIR filter than gets the acoustic job done, ime.
Now that would be Crazy. Shine onMost def!
A One-Wheeled Vehicle Might Be The Ultimate Overlanding Machine - The Autopian
We sometimes accept rather strange things as being normal. A mile is the random-ass figure of 5280 feet. Really? What about the fact that they sell hot dogs in packs of 10 and buns in bag of 8? How long have we put up with that shit? Also, if two points establish a line and […]www.theautopian.com
Minimum phase filters to tame standing wave peaks is one of the best uses of DSP and almost always results in a preferred result.So much better to listen to those 10 db standing waves at 50 and 150 hz in my room than use Diract to correct them, not to mention the group delay on my SVS subs. Right!
Beyond the impulse responses visual differences you said you have been able to hear a difference in the sound of a "long FIR filter" vs a "short FIR filter"? What does it sound like?
Oh no a new rabbit hole to go downYeah, me too. I worked forever to get more taps for low end work. Rather humbling to find out that they aren't really needed, when using more optimal low end techniques.
I'd describe the sound as a little clearer, with more distinct separation between multiple vocalists, and instruments more defined. It's like the background is quieter for everything to heard against.
I kinda theorize that impulse oscillations are some unrecognized form of low level noise or maybe time smearing. Dunno, but do know I hear things more clearly.
Besides minimizing the FIR filter length, the other equally important task for cleaning up FIR filters electrical impulse, seems to be the selection of the crossover frequency and its order.
Out of pass band EQ work that the filter needs, to match the target acoustic crossover, increases impulse oscillation quite a bit. It's cleaner to just use a higher order crossover, to avoid needing out of band EQs imbedded into the FIR filter. However too high an order lengthens the FIR filter, and the oscillations. Right now, if I had to choose one order as optimal for any xover anywhere, I'd probably pick 60dB/oct. Anyway, I digressed for those interested in muti-way DIY speaker building....
One thing I do strongly believe in now, is to not only look at acoustic measurements like we do, but also look at the electrical filters measurements. Regular impulse, ETC, and step, all give a picture of what's being applied in time.
Worth doing for straight minimum phase work too I think, as post ringing can also be minimized.
Why are you using % instead of db? So your saying the filter with all the overshoot is better? It dosnt look as acurate.Oh no a new rabbit hole to go down
See below, first graph is step response for my "old" correction filter generated in REW using VAR smoothing and 96 KHz to just above Schroeder. (I used to upsample everything to 96 KHz so I could use the same FIR room correction filter for all content but stopped that after I realized the resampling was causing digital clipping issues).
The second graph is my "new" light handed correction filter generated by REW from the same measurement and same target but using ERB smoothing and 44.1 KHz. I definitely prefer listening to the "light handed" correction even though if I measure the corrected response at the listening position it is considerably "less smooth" looking.
I am not experienced in correlating "looking at a step response and correlating it to what I hear" but just looking at the graph of my "old" filter it looks scary. I am starting to think "over doing" DSP is a very real and common thing.
They add maybe $100 to the price of an amp. How could that be called overpriced?Anyone else feel DSP is an overpriced graphic equalizer ? And similar results can be had with one. Obviously you cant do so much like speciality low/high pass filters etc, but for generally tuning speakers and to a room or preference of sound aren’t they much of a muchness.
In REW under the impulse tab I guess % is default? If it isn't I changed it on accident. I prefer listening to the second filter which uses much smaller corrections due to ERB smoothing before creating the correction. What I don't like about looking at the graph of the first filter is how long it rings. As I mentioned I don't have a feel for looking at a step response and correlating it to what I hear.Why are you using % instead of db? So your saying the filter with all the overshoot is better? It dosnt look as acurate.
not that type, if it's built into an amp fair enough but standalone units I meanThey add maybe $100 to the price of an amp. How could that be called overpriced?
