You hear those differences when your brain knows what's playing. Do a level matched double blind test to find out what the brain says when only the ears deliver information.
MP3 is lossless and depending on bit rate and your ears may sound different compared to FLAC. However:
- FLAC is lossless and hence the truth even if you prefer lossy MP3.
- If any change in treble is audible I would expect MP3 to have less treble and air, at least for lower bitrates, where all content above 16 kHz is thrown away,
Still how can we have an opinion from listening with regards to DSD vs 1536 khz when there is no ADC to record at 1536 khz?
IMO, no it does not count. I can upsample CD to 1536 khz, but why?Does upsampling to those frequencies count? I have no idea, honestly.
This is hardly worth the bother of testing. PCM 24/1536 is 73.7 Mbit/sec (compared to measly CD at 1.4 Mbit/sec) so that's way more than DSD64 (2.8 Mbit/sec) or even DSD512 (22.6 Mbit/sec). PCM 24/1536 must sound at least 3x better than DSD512; it's practically approaching vinyl!I think that would be a great blindfold test - "can you hear the difference between 1536kHz or DSD 256/512."
Oh c'mon, which one is better:IMO, no it does not count. I can upsample CD to 1536 khz, but why?
I don't think it works that way.This is hardly worth the bother of testing. PCM 24/1536 is 73.7 Mbit/sec (compared to measly CD at 1.4 Mbit/sec) so that's way more than DSD64 (2.8 Mbit/sec) or even DSD512 (22.6 Mbit/sec). PCM 24/1536 must sound at least 3x better than DSD512; it's practically approaching vinyl!
Sex
Or,
Sex Sex Sex Sex Sex Sex Sex Sex Sex Sex
Sex Sex Sex Sex Sex
Thanks for the link, I'd thought of it, been meaning to look it up. I was thinking they - some, like the big fruit bats I know - must have a much wider range than humans, because I can hear them, loud, even though my hearing only goes up to 11-12 kHz. Although that was 15 years ago, maybe I could hear up to about 15 kHz then.Actually, that's too high even for a bat, since they top out at 212kHz.
Higher sample rate giving wider bandwidth or higher frequencies. That's really all it does.I'm getting confused here, high fequency sound versus sampling rates.
A whole lot of bits being wasted for sounds that can't be recorded or heard. Your data storage gets all filled up sooner with zero sonic advantage. 100% virgin snake oil.Higher sample rate giving wider bandwidth or higher frequencies. That's really all it does.
Fixed it so we can be in agreement.I know people say 'it's bit-for-bit', but to myearsbrains, a CD has a more 'liquid' sound - hard to explain. It's almost as if some of the imaging was taking away. Just slightly, nothing dramatic. And as I said before, MP3 320 does seem to have more of a treble response.
That's because the MP3 algorithm throws away more than just top end - it employs a psychoacoustic model to throw away stuff we (usually) won't notice is missing.I will be 55 in October, and I can't hear above 13.5 or 14 kHz. If the MP3 algorithm throws away information I can't even hear, (at 16 K), but I still tell the difference between lossless and MP3, then it has to be more than that. To me, MP3 320 SOUNDS like something is 'missing', not smooth at all.
Exactly. Usually, or sometimes, and it depends on the music, on the production. And maybe even on the neurology at any particular time.That's because the MP3 algorithm throws away more than just top end - it employs a psychoacoustic model to throw away stuff we (usually) won't notice is missing.
"High-end audio is all fake in the end, so just buy the fake that sounds best to you." Not sure who said this.
