DSD playback
Fully agree. I have great respect for the JRiver team so had a quick look at their DSD Wiki:
Quote: The total amount of data from this conversion grows by 8x, so the process is effectively lossless / perfect.
Source: https://wiki.jriver.com/index.php/DSD
So unless Tom C can provide a link to JRiver's 'bit perfect conversion position' I don't believe they ever said that.
"Effectively lossless / perfect" is probably accurate but I don't think that anyone can say that a DSD-to-PCM or PCM-to-DSD is bit-perfect unless it is tested by reconverting back to the original format for comparison.
I don't know if this helps, but I use JRiver with an ADI-2 DAC and RME's drivers. Using the following settings it will play back 16bit 44.1khz WAV files and DSD 256 without having to change any settings when switching between the two formats and without any problems:
I tried yesterday to do it bit perfect or at least close to that & it worked. First I converted 192000 Hz 24 bit flac to DSD 128 & then back to Wav 352800 16 bit. Got a exact same size, it does sound the same as DSD (software did apply filter). Unfortunately I can't neither show you plots for DSD or 352800 Wav but here goes one's from original & 176400 wave afterwards.
Best regards.
Yes. Thanks for the clear illustrations of what we have covered.
Since we are on the subject of DSD and PCM, are there any program that can apply EQ to DSD file without convert it to PCM? Thanks.
To do any EQ on DSD it has to be converted to PCM first. That's why most professional studio's record in a PCM format (DXD) first and convert it to DSD afterwards. There are some classical/jazz labels who record directly in DSD, but they spent a lot of time with microphone placement, because, once they are recording, nothing can be changed/adjusted anymore.
So, to answer your question: There are no programs that can apply EQ to DSD directly without converting to PCM first.
Same here. OTOH, I can use Jriver's internal volume control to operate the volume control in my exaSound DAC in PCM and in DSD but that requires a proprietary driver from exaSound.
You are welcome.
Understood that there may be "zero loss of fidelity" but it is hard to say that the conversion is "bit perfect" since the bits in PCM and DSD are different.
I see. Lossless/perfect is not identical to bit perfect. Live and learn.
