THANK YOU! I did a search for the "Pultec-punch" and came across a few resources, including this thread on ASR where you contributed. I am trying to wrap my head around exactly what it is and how it works. I think the easiest way to try it out is to download that Puigtec plugin before I try to simulate it in Acourate. Please give me a day or two to digest this information because it seems confusing and counterintuitive to me.
You are welcome
A few more notes on this:
- the Puigtec plugin is a great start, it mimics the original hardware's behaviour but it won't allow you to set the Q value (the amount of resonance). You will only have the default settings. If you try this plugin I recommend setting the Frequency to 20Hz and then do the boosting
- additionally to the Puigtec plugin, just try an all-purpose EQ, like the one I showed above (that is the T-Racks EQual but others such as CraveEQ, GrandEQ, FabFilter Pro-Q, etc. would be great too) and try fiddling around with the curve as I mentioned above. For example set the Frequency to 75Hz then apply a boost of 6dB and then play around with the Q (or Resonance) value to hear the difference it will make. If the plugin has steepness control (dB/octave) then try a 24dB/octave value (=4th order)
