Drop + Grell OAE1 Headphone Review
Rate this headphone:
    Votes: 124 80.5%
    Votes: 22 14.3%
    Votes: 6 3.9%
    Votes: 2 1.3%
This is a review, listening tests and detail measurements of the Drop+Grell OAE1 headphone review. It was kindly drop shipped to me by a member. He tells me you can pick it up for $100 now.
The OAE1 is an attractive headphone. It is quite light and comfortable to wear. The lightness does make it feel cheap when you first pick it up though.
Drop+Grell OAE1 headphone Measurements
As usual, we start with our frequency response measurements:
Starting from the top, no matter what I did, the one channel had 1 dB or so less output than the other. Past that, I was surprised by this unique response. We do have good bit of bass which is nice. But what is with the sharp shortfall above 5 kHz? We also have too much energy in upper bass and too little in lower treble. If we look at the impedance measurement we can see something going on above 5 kHz, indicating some kind of passive filtering:
So that chunk is taken out on purpose. Combine with extra bass, this headphone is going to sound pretty "wooly."
Back to frequency response, this is what you are facing if you want to EQ it:
Drop + Grell OAE1 Open Back Headphone target frequency response measurement.png
These are broad, low Q regions so very audible colorations.
What was a shocker was the level of distortion:
Drop + Grell OAE1 Open Back Headphone absolute THD distortion measurement.png
Not only is the bass is out of control at higher volumes but so is anything above 500 Hz. Even at 94 dBSPL, we have 0.5% distortion. Company advertises a very low distortion of 0.05% at 1 kHz. I measured 0.1% which is not far off from what they spec. If they measured though, why didn't they take a look at the rest of the spectrum?
Group delay is a bit messy but not much as many other headphones:
Sensitivity is on the low side:
Drop+Grell OAE1 headphone Listening Tests
First impression I got was that of bass. I ran my sub-bass track through it and it reproduced that region very nicely. Encouraged, I went to the next track, only to be overwhelmed by dominance of upper bass. So dialed in some EQ for that which provided some relief.
I then queued up one of my key female test tracks, London Grammar Hey Now and I was shocked by the warbling in her voice. It was nominally audible at standard listening level. Crank it up and it proportionally got worse and worse. At high volumes, the warbling was just incredible -- in a bad way. I have, never, ever heard this kind of distortion in a headphone. Bass distortion, yes. But not in vocals. Of course we have indication of this in the measurements in the distortion hump starting from 400 Hz.
Just to be sure, I went back to my everyday headphone (Dan Clark) and same track and setup sounded clean as a whistle. Back to Drop+Grell and same problem. At this point, I saw no point in finishing the EQ assignment and called it done.
We have decent looks here especially for $100. And comfort to go with it. But what the heck is going on technically? How could the legendary Axel Grell be involved in a headphone with such poor performance, objectively and subjectively? Maybe some part substitution by the Drop contract manufacturer? But then what is the explanation for that big treble notch? Wrong value used for the filtering???
Needless to say, I cannot recommend the Drop+Grell OAE1 headphone at any price. I guess we shouldn't shed much tear for Drop shutting down its doors....
I'm not sure why but this seems to work for me - yes they are bassy and a bit dark, but not as one might think.
Currently listening signature version - according to my listening tests signature version seems to have selected drivers as distortion seems to be lower.
I mean I can get them to distort but at much higher levels than the regular version - which I also own.
As for the tuning, Axel aimed for very different approach.
And as for passive components, yes it has it:
Photo from https://den-fi.com/grell-oae-1-review/
ps. I like them so much that I own 3 pairs - just for a spare. They are not perfect but somehow I like them and use it as my daily driver.
as for FR it's not by mistake, the choice was made on purpose nothing is by accident.
Open question is if it works or not, for me yes.
OAE1 is also one of my guilty pleasures. : ) Nevertheless, I apply 3 high shelf filters to make it fit to my preference.
I get it ;)
Currently, there’s a demo tour of the OAE2 on Head-Fi that I’m participating in.
I hope to get a pair soon. I’ll post a review on Head-Fi, along with some measurements (iec711 clone with kb5001 clone) comparing the OAE1 and OAE2.
It seems like the OAE2 tuning is more agreeable
The filter attenuates -7.5dB at 5kHz, Q = 2 to 2.5
The inductor has a 3 ohm resistance.
I suspect the inductor to be around 470uH and cap to be 2.2uF (in that case)
didn't like the OAE1 in multiple demos. Found the OAE2 reasonable on head during my demo sessions. Sounds much more put together even if not without notable weirdness with harmonics being blunted on stuff like snare and claps
Thanks for the review @amirm . Interesting to see the difference in members' opinions on these and the measurements.
I had these headphones and they were so disappointing! Very wooly/blurry sound. Low fidelity!
Think I’ll keep my HD 650’s.
Just edited to add this. I know it’s a small sample so far, but 95% poor? Is that a record?
I created the dip with eq and the effect is indeed that the sound moves to the front. So what Grell says about the dip is no nonsense at least.
Edit: Only with live music really. Studio music sounds strange.
I remember trying them about 2 years ago in Munich. I briefly spoke to Axel Grell afterwards and basically asked: "Why?" (after I told him that his headphones were the reason I ever got interested in good sound), because even in the poor listening atmosphere there it was obvious that they sounded strange. He basically told me a short version of the video posted above, and that it works especially well for recordings of live music.
I remained skeptical but bought them later when they became a bit cheaper. They sound as odd as they measure and don't get a ton of usage (comfort isn't that great either). They do work for live recordings though, the heavy bass, strange positional effect and some general oddness in the sound do somewhat resemble concert sound (at least for Rock/Metal/etc.). Not really in a good way though since honestly, concerts aren't worth going to for the sound quality...
Would love to see a similar analysis of the just released OAE2.
Thanks, Amir. Obviously not a very good headphone. There are so many better alternatives including a host of IEMs in that price bracket, that it makes no sense to spend time and energy trying to tweak or EQ something like this one. If it comes down to under $25 and you draw someone you don't like in your Christmas Gift pool, then it's perfect.
Too much distortion for me. Hopefully they did better with the newer version. Thanks for the great review.
Following Corsair's acquisition of Drop, the remaining OAE1 are being sold on Amazon for $68. Meanwhile, Grell is now selling the OAE2 and there are reviews online.
Corsair bought Drop? I haven't picked up anything from their site in years but this seems like a good reason to stay away. I'm sure the headphones and DACs with RBG light strips are on the way.
So I guess they've mainly done that to reduce the peak at 4.5kHz? I mean there's still a peak there but Q2 or Q2.5 filter at 5kHz will definitely significantly affect 4.5kHz when you're talking -7.5dB for that filter. If they hadn't have put in that passive filter, (based on what you're saying), then that peak at 4.5kHz would have been absolutely massive. I suppose they didn't put it at 4.5kHz because they probably wanted to preserve some of the frequency response energy below 4.5kHz. Just thinking it through. Seems for whatever reason their hardware design (before passive filter inclusion) has created a massive 4.5kHz peak inherently, either on purpose or a somewhat unwanted side effect.
