That's a good point, and you really should focus on that if you continue to have bad clipping whilst not having adequate bass, but the changes I was showing you was to preserve a linear flat bass extension to 20Hz, but just at a lower level. If you want to experiment with higher bass levels whilst cutting out the lowest subbass, then you can follow my previous advice but also add a High Pass Filter to cut out the subbass, so that might enable you to get the best of both worlds.
Now, the High Pass Filter you want to use, well start with a 12Hz Q0.75 High Pass Filter which will not effect frequencies above 20Hz, but will remove below 20Hz (this might be too low(probably), but try it), following are pics illustrating the effect of this filter (note that this screenshot was done ages ago before I really knew about EQ properly, but it illustrates the point):
before High Pass Filter:
after High Pass Filter:
That's probably a bit mild for your usage scenario, so I'd go with at least a
17Hz High Pass Q0.75 combined with the recommendations I gave you in the previous post, especially if you don't want to do that negative dB 105Hz Low Shelf I mentioned. So you could keep the stock bass of the headphone and roll it off with this High Pass Filter. You could even experiment with doing what I said in my previous post but instead doing a +1dB Low Shelf at 105Hz and upping the High Pass to say
20Hz High Pass Q0.75, maybe even
25Hz (or higher up to 30Hz max I'd say during which point you're losing the normal wonderful bass capabilities/benefits of EQ'ing headpone bass). The thing to remember though is the Q0.75 is important so that it doesn't change the shape of the frequency response above it - if you put in a higher Q and make the cut-off sharper then it will also boost the frequencies above it "proportionally", so to maintain the overall shape of the bass and provide a slow roll off then you'd use a Q0.75 High Pass.
If you want to experiment with EQ filters, then REW (
https://www.roomeqwizard.com/ ) is an absolutely awesome & free program that is ridiculously powerful & flexible if you've spent a lot of time with it!
