Oukkidoukki
- Joined
- Sep 6, 2018
- Messages
- 500
- Likes
- 234
This is quite weird. I have k702 and they are absolutely great. No distortion whatsoever. I assume drop model is pretty much the same.
I'm going to investigate my pairs here for sure. I am seriously interested to see if all my AKGs have >0.5% THD right in the midband at levels in the mid 90s.
Still, for the quality as tested, about 180€ too expensive.The K7XX is actually a cheaper model ($ 200) compared to the K712.
About the same price as a K702 + loose K712 pads.
A very good point. A lot of people see distortion numbers and assume we both know what that means and what it would translate to in the listening experience. I am not sure, speaking for myself and I suspect quite a few "lay" members (those without technical education/ experience in the field), that is actually the case.I also love mines, bought 12 years ago, but now I'm little puzzled because I'm not sure if what I love is the distortion. I assume I should learn to hear distortion.
With the excitement of seeing my (almost) headphones reviewed I forgot to thanks @amirm for this review.
Well, if you are lucky to get one of them without the distortions (as shown by Robbo99999 in post #12), and use oratory90's EQ, then they are well worth their value, because of the comfort and great soundstage. In Europe they cost the equivalent of $160. (I am talking about the K702, not the DROP-version)Still, for the quality as tested, about 180€ too expensive.
One of mine does, one of them doesn't:Graphs from Crin show that K701/702 and K7XX are actually quite a bit different. It would be interesting to know if K702 exhibits the same distortion problems though.View attachment 139260
If you can have some headphones that works great with DSP, relatively cheaply, why buy some more expensive?OK, probably. Maybe the future is active, with most problems "DSP"-ed away? but this would be OT here.
Is it theoretically impossible, given enough information about the specific driver and some adaptive non-linear (deep learning?) filter?You can't DSP distortion away though as it differs per amplitude and driver.
Yes, but if you are the manufacturer you could make some kind of complete system identification and supply some software with your headphones, that could implement the DSP. You could even include some calibrated mics inside the headphones, so that the DSP could do some real-time control-feedbackIt will still depend on the measurement method. One would also have to include variables like seal, pad wear, ear shape/size etc. and above all which measurement method and targets are used.
Where do you set the audible treshold for distortion, and based on which rationale?at comfortable listening levels remain below audible levels.
