Richx200
- Joined
- May 20, 2024
- Messages
- 160
- Likes
- 55
While reading Dr. Toole's book "Sound Reproduction" I came across the attached chapter 13.2.3 "Room Correction" And "Room Equalization" Are Misnomers. If I'm correct, Dr. Toole is saying that very good loudspeakers should not be equalized above transition 300-400 Hz and doing so could degrade a very good loudspeaker. All that is needed are adequate specifications on the loudspeakers. Anechoic data on the loudspeakers would indicate that the loudspeaker was not responsible for the small acoustical interference irregularities seen in the curve.
So I went about in search of the adequate specifications for my Focal Aria 936. I couldn't get them from Focal, and only one place had them;
www.stereophile.com
So I copied the data (attached) and it looks like I may not need to use any automatic calibration at all. I think I can correct the low frequency hump with the subwoofer's PEQ if I need a little more; I may have to touch it up with equalization; nothing above 400 Hz.
I hope I'm right about what Dr. Toole is saying and this information maybe valuable to others. Please excuse the sloppy attachments, I'm not very good at copying pages from books.
Focal Aria 936 loudspeaker Measurements | Stereophile.com
Sidebar 4: Measurements I used DRA Labs' MLSSA system and a calibrated DPA 4006 microphone to measure the Focal Aria 936's frequency response in the farfield, and an Earthworks QTC-40 for the nearfield responses. The Earthworks microphone has a small, ¼" capsule, and so presents minimal...
