Could it be that because they are a closed design, which is seriously under represented these days, that provides the biggest advantage in terms of transient response?
And gives the advantage over most bass-reflex speakers in terms of "clarity" and "details".
That’s certainly one of the claims made by closed-box advocates. There’s no doubt that closed boxes (assuming no signal processing) are capable of superior transient performance. There are two possible means by which this is the case.
Firstly, a closed box will have approximately half the phase shift of a ported box (180 deg vs 360 deg), translating into half the group delay for a given F3. This is a low-frequency only phenomenon.
Secondly, a closed box can be stuffed more densely, more effectively absorbing the woofer’s back wave and potentially thus improving its transient behaviour by reducing interference on the cone’s motion from internally reflected waves. (Well, you
can stuff a ported box very densely if you like, but the port will stop functioning beyond a certain point.) This is primarily a mid-frequency phenomenon.
As to the first point, I’m not aware of any published scientific evidence demonstrating that a phase shift in the range of 360 deg (as is caused by a vented box) is audible at
any frequency, let alone this low down; that’s not to say there is nothing to the claim, but rather that it is yet to be scientifically demonstrated.
Similarly, I’m not aware of any
specific research into the audibility claim regarding back-wave interference, although it seems more plausible to me personally that this should be an audible concern - albeit possibly not due to time-domain effects specifically.
Also keep in mind that, with digital signal processing, the transient response of both sealed and vented boxes can be corrected, at the cost of (pre- and post-) ringing.
The main disadvantages of closed boxes - as alluded to by Mr Heinz - are related to excursion, with closed boxes tending to result in higher distortion, less extension, and reduced max. output compared to their vented counterparts (with many complicating variables at play ofc). These issues have nothing to do with transient response per se.
