I read this thread and wonder why the detractors don't download uBACCH and try it.
Turns out this is terrible advice, if your aim is to promote BACCH. At least in my system, uBACCH stinks.
BACCH does not alter the tonality, does not make it sound "phasey". It improves the definition of the image and widens the soundstage.
I can only surmise that uBACCH and BACCH4Mac are entirely different beasts, because the above is not my experience. uBACCH will widen the soundstage, yes, but not in a pleasant way.
My system is a DLBC setup with stereo speakers and currently two subwoofers. Listening room and speaker placement are symmetrical. The room is dedicated to music listening and fairly well treated with bass absorbers, first reflection absorbers and diffusers as well as ceiling absorbers and diffusers. I get very good imaging out of recordings that have it in them. I inserted uBACCH between source and Dirac Live Processor (because that’s where things are still 2-ch). I also tried uBACCH with Dirac out of the chain or partially (gain and/or delay compensation) disabled. Dirac and uBACCH do not seem to interfere with each other in a deleterious way, what I observed below was largely the same with or without Dirac.
Initial setup of uBACCH was dead easy and quick. Both measurements and by-ear tuning landed on the same spot, 28 degrees. I had to dial down the centre gain all the way to -3dB, because otherwise the tonality would shift and the soundstage would get pancaked back to front. With centre gain at -3dB, sources right in the middle between L and R were left untouched by uBACCH, they sounded virtually the same with uBACCH on or off.
It’s the off-centre sources where uBACCH goes to work. It will stretch or smear them, the further from the centre the bigger the effect, in an arch extending outside and around the speaker towards the listening spot. In well done acoustic recordings of symphony orchestras, chamber or jazz bands this wreaks havoc with imaging. Instruments or instrument groups that used to be pin-point will get blurred and lose focus. Sources placed at the extremes of the soundstage get transformed completely. For example, in the 1960 Decca recording of
Carnival of the Animals (LSO, Skitch Henderson), the double bass portraying the elephant (about 8 min into the track) is placed pretty far right. In my system it appears somewhat to the right of the right speaker and about a metre behind it. With uBACCH enabled it turns into a dark cloud that fills most of the right side of the room, extending up to the listing position. The instrument is being replaced by a sound effect.
I tried lots of recordings of classical and jazz that way, from single-microphone captures to conventional takes, none of them improved with uBACCH and all of them suffered loss of imaging clarity.
There are some recordings that didn’t seem to suffer. Madonna’s
Immaculate Collection, for example, being recorded in Q-Sound, has these all-round-your-head effects in several of the songs. These effects are amplified, and I can see how people might consider this an improvement. Likewise, I can imagine techno, trance, chill, etc. to be enhanced by uBACCH. There may be other kinds of music that will benefit, that I have yet to try.
I’ve got two weeks for the trial and I will use them to try uBACCH on many more and varied recordings. If I find anything new or interesting I’ll report back. For now, I wouldn’t spend ten bucks on this plugin, let alone a thousand.
YMMV.
