Douk H5 Stereo Tube Preamp Review
Rate this tube preamp:
    Votes: 58 44.3%
    Votes: 45 34.4%
    Votes: 24 18.3%
    Votes: 4 3.1%
An alternative to the Douk Audio H5 is the Aiyima T20 tube preamp.
The Aiyima T20 measured well enough to be worth the time @amirm spent reviewing it.
Those measurements are pretty impressive for what it is.
True. Although I'm not sure anyone figured out if the tubes are used as amplifiers, or just lit for decoration.
I don't know either.
I consider the tubes in the Aiyima T20 to be amplifiers with measured noise and distortion so relatively low as to offer performance akin to solid state with the decoration of tubes. :)
I welcome the option of the Aiyima T20 preamp when I am asked my opinion of gear using vacuum tubes.
It's obvious.
And the distortion spectrum (predominant even-order) here is exactly what users interested in this type of preamplifier (or amplifier) would be looking for.
Checkout amigo
Ok nice to see some units from this brand that do the job
I was in the impression that douk was only on tubes or so
The D1 is more than correct for the price
Interesting analysis.
Professionally I started working in the opamp era with tubes occasionally in my world. I had a tube power amp. I used tube microphones daily. I DIY built transistor and FET audio systems in high school. I am still curious about tube system data.
I would suggest tube equipment makers, McIntosh, Manley on to Rolls, and many other makers send equipment to Amir for testing.
I would be interested in a teardown and schematic extraction, especially looking at noise sources.
You put the financial aspect of it very well.:)
But even if the hit to your wallet is small—do you really want to revisit that bygone era?
You should look forward and embrace the good new stuff.
I mean, I don’t drive around in a fully restored 70s Volvo on a daily basis just because my dad had one.
a 70s Volvo, in my eyes, isn't that in the slightest, though.
Perhaps this Volvo is better? We call these things sleepers (looks like a restored older Volvo, has massively surprising tech):
There are several reviews that Amir did where he warn companies how he measures in his reviews, yet those companies still sends products in.
I think that saids a lot about the audio market, some people just care about something else that's not measurements. May it be glowing tubes, aesthetics, certain topology, etc.
I think that is perfectly acceptable.
See attached the Topology of the Aiyima T20 preamp
That's what it says on the tubes. Whether they are NOS or clones, I can't say.
They look real enough as far as the images show, FWIW.
Products like this one are designed around tubes for which stocks are still plentiful and cheap (at least for a while); engendering some pretty interesting choices of tube(s). ;)
(another fun fact, Moody Blues has recorded just about the worst phase-y stuff, ever)
+1
One of the worst-sounding commercial recordings I have ever heard was their very early hit, Go Now.
:eek:
Are you sure? Why put the DSP in front of the tubes?
To my understanding, tubes and DSP sit at opposite ends of the audiophile religion spectrum.
The schematic comes from the Aiyima website.... Unless they made a mistake ?
I guess you would have to just yank the tubes out and see if the thing still keeps playing.
An interesting idea. If someone does that, I'm curious enough to want to know (but not curious enough to buy one and check it for myself).
(Relative) Low general noise, high harmonic distortion. That is what most people actually search when they talk about the "tube sound". Off course you can easely make a lot cleaner phono stage, but the high harmonic distortion is the sales argument, it's the "warmth" that many search. So for me this is very fit for it's purpose. Not what i would use, but it does what it promises. And for that price, it's a steal.
Could have done with a mid adjust also and it would have been just what I wanted to add distortion, colouration and a bit of EQ I enjoy listing to.
What else is out there that an do it. Liked the fact it has two outputs as well. And one phono input and one for a DAC, it's almost perfect for me :( Dont care about the measurements, it might be the right tool I need. Looks good too.
Okay, so maybe there is a bit of demand for it, then. BUT 180 Hz or 250 Hz? These are very high cut-off frequencies for the purpose.
I really don't understand this switch, what is its purpose and is it on the input, yet there's no way to bypass it even. It an odd one.
