Douk H5 Stereo Tube Preamp Review
Rate this tube preamp:
    Votes: 58 44.3%
    Votes: 45 34.4%
    Votes: 24 18.3%
    Votes: 4 3.1%
An alternative to the Douk Audio H5 is the Aiyima T20 tube preamp.
The Aiyima T20 measured well enough to be worth the time @amirm spent reviewing it.
Blimey! That's quite an eye-opener for such a cheap tube preamp. :D
Technically, preamp is an amp so theoretically speaking no need to correct. Just teasing... :)
In rational argumentation, words have meaning—this is the principle of identity.
From a technical standpoint, a preamplifier and a power amplifier play distinct roles and complement each other within an audio chain.
These measurements will not pass muster for this group. I guess given the price, if one wanted to try and experience the effects of tube distortion, this would be an affordable way to do it. You are certainly going to get gobs of it in the second and third harmonics. But I think there are a few similar units out there that measure better.
Of course put this in line after your R2R DAC, and be careful to get the right cable match of silver conductor cables, and you may experience elevated conciousness. It goes without saying, but a proper power conditioner must front it all.
For the price of a dinner for two, you can have some fun with this thing, and there are worse things to put on your desktop.
For what it is, this is fine performance.
And probably right in line with Douk's design objective for the unit.
This is one where the ASR rating system is irrelevant.
Ironically though, that might make it less desirable (?)
True - and in rational argumentation, the meaning of words is not simply a matter of the principle of identity - it's also a result of traditional (and sometimes emergent) usage, a social process that's about convention and shared assumptions.
So while I agree that the thread title should be clarified from "amp" to "preamp," it's because of the ambiguity rather than the kind of strict inaccuracy you've asserted. An "amp" is not inevitably or etymologically a power amplifier. It could also be an integrated amp, or simply an incomplete description of a power amp, integrated amp, or preamp (or some hybrid like a power amp with gain controls).
The extent that many or most of us might associate the word "amp" specifically with "power amp" rather than "preamp" (and rather than "integrated amp" - although for the older folks in the audio hobby that latter one is not necessarily a safe bet), it's because we assume amp=power amp by social convention (which convention, I would hypothesize, has been strengthened by the relative decline of integrated amps since the 1980s/90s in favor of either receivers or power amps).
And speaking of the social aspect of using words to communicate, just FYI the only reason I mention all this is because @peng wasn't actually disagreeing with you, as evidenced by the fact that they took the time and thought to write, "just teasing" with a friendly smiley face emoji. But you decided to respond with a lecture, which seems to be to be rather gratuitous in context. (Of course, you are free to say it just as you are free to say whatever you like. But that's of no consequence since no one's stopping you from saying it.)
At any rate, I appreciate this review and I guess it has value in that it might help folks who think they want a tube stage in their system decide whether or not they really want it. The people who want (or are okay with) added nonlinearity to achieve a "tube sound" might be well-served in getting this. Those who think tubes add extra fidelity to the sound might not.
interesting thanks Amir do the noise figures,i.e s/n ratio also apply to the phono input as well? Its noise level is very good for this type and if you want a cheap dose of 2nd harmonic this delivers that,looking at a tube based phono amp thats low noise as well...thanks
Thanks for the additional info. I certainly wasn't trying to lecture him; I just wanted to provide a clarification that would be useful to everyone.)
By the way, thanks to @Amir for making the correction.
Okay, well then, fair enough. All good as far as I'm concerned - and I too appreciate Amir making the correction.
Mission accomplished !!! Classic warm, tube sound at an affordable price.
Enough harmonic distortion to make guitars sound more guitar-y and violins violin-y. Perfect to match with a classic turntable to add even more analog goodness (artifacts), I mean realisms (sic). Spend hundreds more (money and hours) tube rolling. In addition to the warm sound it can help warm small rooms this winter.
I think the manufacturer is adding features that have been requested here and elsewhere - perhaps not the tubes (from this forum), but the sub adjustable low pass is in other products, indicating some users use passive subs? I have an Aiyima with adjustable sub low pass, and with my active sub having an adjustable low pass filter, I don't need it, and have it fully "up", though not sure that disengages it.
Regarding high pass on the line outs, not sure I would need or want that, if your speakers don't handle the rolloff in their designs and need help from electronics, that's a red flag for me on the speakers. You won't find these high pass active filters on say Benchmark preamps or amps (I don't think?), so when did high pass filtering from electronics become a needed feature? They've been optional accessories, in both active and passive modes, but now seem to be required features?
Speakers, especially small ones try to reproduce bass that is clearly distorted. The idea is to roll that area off and augment with a sub, hence the request for high pass filter.
For ASR audio enthusiasts this is probably a better choice
I don't have that with either test tones, streaming from Roon, phonos, or live sound through my KEF LS-50s Amir, I haven't listened for this closely to other speakers, but if I knew speakers had this issue, I'd likely avoid them. I haven't noticed this with my all in one Fostex 3.5" FR Kanspeas on my desk, but the test tones below ~100hz are inaudible to me, not distorted.
Great review, not in my chain for Music reproduction. Does it really come with GE tubes? NOS?
That's what it says on the tubes. Whether they are NOS or clones, I can't say.
