Douk H5 Stereo Tube Preamp Review
Rate this tube preamp:
    Votes: 58 44.3%
    Votes: 45 34.4%
    Votes: 24 18.3%
    Votes: 4 3.1%
This is a review and measurements of the Douk Audio H5 Tube based preamplifier with phono stage. It was sent to me by the company and costs US $89.99.
I know the box looks like any other but it actually has a clear step above fit and finish. The tone controls feel solid with a nice detent. Even the font looks crisp! Addition of a phono preamp is a surprise as well:
As is subwoofer with selectable low pass but sadly, not a high pass for line out.
A compact switching power supply comes with the unit.
Douk Audio H5 Measurements
Based on my standard protocol, I adjusted the volume so that when I fed it 2 volts, it produced the same ("unity gain"). This is what I got:
All the distortion you can eat....
Fortunately not noise:
If you want the distortion, you better drive the unit hard:
Douk Audio H5 Tube stereo Preamp distortion and noise vs level Measurement.png
Below around 0.1 volt it is actually noise limited. So best to pair it with a low gain power amplifier so you could use the full 2 volts.
Frequency response shows a slight channel differential in bass but otherwise, doesn't suffer from out of control tone controls:
Sub output filtering is fine, but I don't know why it has such high gain which gets worse with higher low pass:
Douk Audio H5 Tube stereo Preamp Subwoofer Frequency response Measurement.png
I ran a quick test on Phono input to see if it passed the RIAA equalization test:
Surprising that it has that gentle high pass even when set to "flat."
Asking me to test a tube amplifier is like having a vegetarian rate steaks. It can be done, but the results may not be what you want, a fact that I expressed to Douk. Still, they wanted it tested so here are the results.
Compared to what we typically we review, it is of course a distortion factory. Fortunately, unlike many high-end and expensive tube amplifier, it doesn't pump out a lot of noise to go with it. The switching power supply is partially responsible for not having a spray of mains and rectifier noise. It actually has dynamic range of 16 bit digital audio! So if it is the distortion itch that you want scratched, here is a super cheap tube preamp for you.
Now, serve me some organic, homemade 湯葉 (Yuba) with a side of freshly grated wasabi please...
Objectively horrible preamp, but would be interesting hearing an A/B comparison on some music with and without the distortion characteristics of this amp applied so we could hear how bad it really is :)
I fear that the distorsion level (below 1%) is still too low to get the sound my grandmother’s wooden tube radio had…
@pkane has us covered for this:
Just copy the distortion amount and pattern and test it on the fly.
About this little thing, can't see the use case.
A little of everything but too little?
Thanks Amir!
Thanks for the review, Amir. :) Why? Was it designed to be a distortion factory on purpose? I mean, it is possible to design and build tube preamps with low or acceptable levels of distortion, so why didn't Douk Audio do that?
Amir: As is subwoofer (out) with selectable low pass but sadly, not a high pass for line out.
If I understand correctly, the idea from Douk Audio is that this preamp should be used with the Douk Audio A5 amp, which features an adjustable high-pass filter for the speakers.
Besides, the majority of subwoofers have built-in low-pass filters, so what is the point of that function?
The low noise level was a plus, though.:)
The assumption has been that passive subs are used and hence, they lack filtering. Of course, passive subs have almost no market share so the functionality is legacy.
For $90, someone will like it, and be entranced by a glowing thing on a shelf, and it will sound good enough if you play vinyl.
Okay, so maybe there is a bit of demand for it, then. BUT 180 Hz or 250 Hz? These are very high cut-off frequencies for the purpose. And, if it happens to be a low-order filter—though I don't know if that is the case—it becomes even more problematic. Take a 12 dB filter, for instance: it would only be 12 dB down at 500 Hz with the sub out setting at 250 Hz.
How are you supposed to integrate subwoofers with the speakers sensibly at that point? Besides, you can't use two bass boxes in stereo since it's a mono signal:
(Gemini AI)
Apart from that—which is a perfectly sensible, standard design principle—a pre-amp should have lower distortion than a power amp. It really turns things upside down that this preamp has higher distortion levels than its intended partner, the Douk Audio A5 amp.:oops:
Edit:
Just for comparison, this 15-watt tube amp has lower distortion than the Douk H5 , and it’s a design that’s nearly eighty years old:
Seems to do what it is supposed to do.
Add 'tube harmonics'.
Also you get a 'MM phono pre-amp'.
Just what the young folks want... connect a DAC and a 'record player without built-in phono-pre, have volume controls and (very handy) old fashioned tone controls.
All of this for less than the Schiit tubalizer thingy (Buf).
I say 'great' but would never buy one myself.
:D
11bits of resolution, at best, and much less most of the time, nice indeed :)
The FFT for SINAD looks like one from a phono preamp, with tons of distortion on top :facepalm:
The review title is Douk H5 Stereo Tube Amp Review, but of course, this is a preamp! :)
You have a point there. Besides, the Douk H5 has low noise. By the way, noise vs. distortion—take @pma's blind test for noise and compare that with blind tests for distortion, for example; it is much easier to detect noise. Then there is clearly audible noise—whatever the cause might be—but that is a topic for another thread.
I appreciate manufacturers who engage with ASR.
Given the backlog of gear to be measured, I would have politely asked @Douk Audio why their 'H5' preamp should be reviewed.
@amirm > Title should be corrected "preamp" not "amp"
Teardown see attached files
I voted "fine" because it is the perfect preamp for people who want to try a tube preamp without blowing thousands of $ on a boutique tube preamp. If the like it they can keep it, if not they can sell it with a small loss.
An alternative to the Douk Audio H5 is the Aiyima T20 tube preamp.
The Aiyima T20 measured well enough to be worth the time @amirm spent reviewing it.
