From the review I was not sure the mediocre specs were the worst part. Digital Bass/Treble (knobs that spin with no center detent or beginning/end point) with no indicator would be a nightmare in use. Particularly since the Bypass button disables not only the tone controls but the volume control as well (pushing the output to maximum gain)..... Bass and treble controls are provided but alas, I could not figure out how to center them. They are rotary controls so keep turning and there is no indication to tell you where you are on the dial. For this reason, I stuck to the "bypass mode" for review that defeats those controls and that of the volume (turning it into a power amplifier).
However, the manual states the G7 uses LED indicator lights to denote minimum, center, and maximum (+- 10dB) Bass and Treble. This is still not great, a numeric display for digital controls is much better.
Another potential usability problem is the big "Bypass" button dead center on the remote control. Pushing it decouples volume/bass/treble; resetting B/T to Center, but the Volume to Maximum. Ouch, that could hurt. Fortunately the manual states you have to long press the button for 3 seconds for it to engage/disengage. So, perhaps less likely to be activated by accident unless you lose the remote under a cushion.
