Isn't that the whole point. The meters are supposed to indicate the power into the amp. If the volume is low, there is (very) low power - that is what the needles will show - almost no movement.Hello. It will work on low volume? I bought vu3 pro and dissapointed that needls stay dead on low volume on max gain setting I need meters that works independently from volume. This model will work?
I see sensitivity or gain adjustments on the Vu2Pro designs, which should allow adjustment so the meters can bounce nicely (though not independent from volume) most all of the time. I agree, that is importantHello. It will work on low volume? I bought vu3 pro and dissapointed that needls stay dead on low volume on max gain setting I need meters that works independently from volume. This model will work?
That one does measure, but on consumer amps or accessories like the Vu2Pro (as opposed to recording devices/mixing boards) were never primarily for measurements, right?I remember it (Technics SH-9020) from the days I worked at Technics/Panasonic service center.
It actually was a measurement device.
No. I had phono preamp with meters, they worked always independentlly from volume. I want vu meters for visual AestheticIsn't that the whole point. The meters are supposed to indicate the power into the amp. If the volume is low, there is (very) low power - that is what the needles will show - almost no movement.
vu3 pro also has gain and sensetivity adjust but even on max sensetivity and gain its not work on low volume. But vu3 pro works with speaker wire terminals, vu2 pro will work with rca. Thats why i am interested how it will work on low volume. My phono preamp with meters worked always independently from volumeI see sensitivity or gain adjustments on the Vu2Pro designs, which should allow adjustment so the meters can bounce nicely (though not independent from volume) most all of the time. I agree, that is important
It should be simple enough to include an auto-gain mode (and gain indicators) that self adjust the range so you always can see movement. that could please both utilitarians and aesthetes
Not in consumer amps or accessories I think, in recording devices and mixing boards for sure.
On Pro Amps meters are quite rare, See Studer's Pro A68 (no meters) vs. the Consumer Revox A740 (meters). Pro Amps (where overdriving is far more likely) use Peak leds if anything at all.
On consumer gear, hearing sound but seeing no meter bounce, is not only unsatisfying but makes one question whether something's busted.
My tardy vote supports a Microphone option (for full transparent operation) as well as sensitivity gain, preferably automatic self adjusting. Alternatively, some kind of logarithmic scale could allow for satisfactory bounce at low levels without pegging the meters at high. How about adding out-of-phase indicators with dual stereo mics, (flashing bright red) reversed polarity speaker connections.
The "Pro" audiophile version of anything these days must include XLR connections I guess, but it is odd to be so concerned about noise to insist on balanced connections, yet not concerned about adding another AC powered device to the chain.
That is because volume is controlled AFTER the phono pre amp. If you want that behaviour, then put the meters between source and volume control.No. I had phono preamp with meters, they worked always independentlly from volume. I want vu meters for visual Aesthetic
The final version of the I/O interfaces of the VU2PRO (Both black and silver will be available. However, the silver version only has silver front and back panels, the edges are black.
No duh. The point is swinging meters. Have you ever used one of these?Isn't that the whole point. The meters are supposed to indicate the power into the amp. If the volume is low, there is (very) low power - that is what the needles will show - almost no movement.
No, the size of the VU meter is still the same as the VU2.Will both colors use the larger meter?
Hello. When new product will appear on market?No, the size of the VU meter is still the same as the VU2.
Hi, according to the PD's plan, the VU2PRO is currently expected to be launched around the beginning of June. Thanks for your attention!Hello. When new product will appear on market?
Thats really nice. So finnaly it can work in peak mode independently from amplifier volume level. I mean version with line inputs and outputs.Quick update: Below are the front and rear panel of the VU2PRO and VU3PLUS (The top one is the VU2 Pro, and the bottom one is the VU3 Plus.), display the accurate level or power.
In addition, both of them will provide silver version.
Yeah, you are right!!!Thats really nice. So finnaly it can work in peak mode independently from amplifier volume level. I mean version with line inputs and outputs.
From my personal perspective, I think this is a great suggestion!@Douk Audio Any thought about putting a trigger input?
