@Douk Audio
Hi, I'm considering buying the Douk Audio U2 and have one question before I order. I'll be using it with a Mac, connected via USB, with the audio going out through the Toslink optical output.
My requirement: the Mac's own system volume slider and keyboard volume keys must still work to control the volume, not grayed out/disabled and no software workaround.
I understand this depends on whether your firmware has "master volume control" enabled in the USB Audio Feature Unit descriptor (I think earlier XU208-based U2 units supported this, and I want to confirm the current XU316 model still does).
Can you confirm:
does the volume slider in macOS Sound settings work (not grayed out) when using the U2's optical output, or is the digital output fixed-level/bit-perfect only?
Thanks!
Can you confirm:
Thanks!
