I bought mine here and was quite a bit cheaper than on Ali.Wary about direct shipping like Ali these days, any reasonably priced trusted USA source?
doukaudio.com
Please offer the Amp without a powerbrick to save some money. I already have enough power bricks, thank you!Hello all ASR members,
Recently we have launched a series of TPA3255 digital amplifiers, and we have also received a lot of feedback from audiophiles about adding high-pass filtering.
Therefore, we have done some research and designed an A5. The following are the functions and appearances that have been temporarily determined. Please take the time to have a look, share your thoughts and shape it together!
As long as a correct power brick is an option.Please offer the Amp without a powerbrick to save some money. I already have enough power bricks, thank you!
Looks like I showed up after the party ended, but I don't see a need for a HP filter above 100hz. The 48v should be the only option, otherwise the power specs are invalidated, and people will feel scammed that they can't achieve the claimed power. Also, stop listing BS power figures (like @ 10%THD). Please make sure the aux out level is controlled by the volume knob. Also, I like the removable lid. I'm not a child, don't need to be protected from myself, and will run it without a lid for better cooling.Hello all ASR members,
Here are some highlights of the A5:
1. With acrylic window design on the top just like our DAC-Q11.
2. Easy to switch the op-amps, just take off the acrylic window and no need to remove screws.
3. Three backlight colors can be displayed individually and also can be mixed freely: blue/green/orange, the color switch is inside the A5 but easy to select and mix from the window.
4. Add HPF filter, the range can be adjusted from 60Hz to 6KHz.
View attachment 395389View attachment 395390
Here are some questions that need your suggestions:
1. What range of the HPF filter adjustment is better and suitable for most audiophiles' use?
2. What power adapter is better to match with the A5 considering performance and cost performance? Below is the estimated price:
A5 with 32V5A power adapter, $79.99
A5 with 36V5A power adapter, $89.99
A5 with 48V5A power adapter, $99.99
Which one do you prefer?
Basic Function and Parameters
Audio input: stereo L/R RCA
Audio output: Banana speaker jacks / 3.5mm AUX
Max power output in theory: 300W*2 (4 ohms, THD10%)
Frequency response range: 20Hz-20kHz (±1dB)
THD+N: 0.007%
SNR: ≥110dB
Working voltage: DC 24-48V
Of course, other suggestions are also welcome. Thank you for sharing your opinions in advance!
It is.Please make sure the aux out level is controlled by the volume knob.
Other than sentence 1 (my personal subs have an FR of 20-80HZ [but I can see some people needing to the 200-250 HZ zone]),Looks like I showed up after the party ended, but I don't see a need for a HP filter above 100hz. The 48v should be the only option, otherwise the power specs are invalidated, and people will feel scammed that they can't achieve the claimed power. Also, stop listing BS power figures (like @ 10%THD). Please make sure the aux out level is controlled by the volume knob. Also, I like the removable lid. I'm not a child, don't need to be protected from myself, and will run it without a lid for better cooling.
The aux is full signal no matter the setting on the HPF knob, on or off. The HPF removes any signal from the speaker level outputs below the frequency set on the knob. (Well, that's a rudimentary explanation, there's a falloff curve, but you get it.)I'm a little unclear what the HPF does.
Does it pass the filtered highs (IE. >100Hz) to the speaker level outs, and full spectrum to the Aux? Or does it it pass the filtered highs (IE. >100Hz) to the speaker level outs, and pass only the lows (IE.<100Hz) to the Aux? Or is it the other way around where only the lows are passed to the Aux and full spectrum to the speaker level outs?
Sure do. Thanks!there's a falloff curve, but you get it.
Someone might, but I don't! I'm pretty shocked at the YouTube reviews though. Pretty high praise (typically with something like Sparkos op amps added, which members of this forum might not care much about, but I'm keen to try for myself at some point.)And at this point we don't know what the SINAD is correct?
I don't think that it needs so many hash tags (60, 80, 100, 120, 150 Hz) would likely be enough to let you know you're settings.Finally, an adjustable HPF on an amp! (Now if all preamps would just include one... and maybe a LPF too!)
Just a few silly mistakes I see made on the A5 amp...
1) need hash marks every 10hz showing adjustment range on the HPF knob so you know where you're at. (Even if ultimately you measure with REW this would be helpful, especially as you are fiddling with it.)
2) Stick the HPF knob on the back, not the front. Or put some sort of feature on it that keeps it from being accidentally adjusted once set. Once someone gets that setup and blended perfectly along with their sub's LPF, they are going to be ticked if it gets accidentally adjusted when they go for that volume knob.
3) RCA for sub out /aux would be much nicer for those with good cables. No one wants to buy a crappy splitter.
4) RCAs are too close together for some cables.
Also, I would note on your product page what type of filter the HPF is. Digital/Analog? Linkwitz-Riley or... ?
But altogether, SO happy to see this product! As many new audiophiles are using desktop 2.1 systems, this has been greatly needed!!!
