Douk Audio H7 Amplifier Review
Rate this stereo amplifier
    Votes: 16 6.7%
    Votes: 81 34.0%
    Votes: 123 51.7%
    Votes: 18 7.6%
Are you saying that listening tests on amplifiers are "Science"? Hmm... :rolleyes:
This amp receives a recommendation while the Topping TP60 with essentially identical performance does not- and Amir didn't even listen to the TP60. Science? Not so much.
Same performance? you may want to look at that again. Near 10dB sinad difference, and the TP60 unstable at power on - just two issues sufficient to cause a difference in recommendation. Then look and feel, case, meters etc. I haven't checked in more detail, if I did I'd probably find more.
You left out the HT7's switchable XLR/RCA input jacks and the TP60's oddball, more or less obsolescent -- or at least out of fashion nowadays -- Class T "Tripath" output circuit. :facepalm:
Douk Audio lost sight of the usability of their 'H7' amp in deciding on separate volume controls for the Left and Right channels.
The H7 is an acceptable value at the discounted price of $59.99 as a 'balanced power amp' - with another device upstream to control volume.
The issue with usability was later rectified with the introduction of a balance control on the Douk Audio 'H7 Pro' amp.
Well, it is a power amp AFAICT, and separate gain controls per channel are pretty traditional in that product category, e.g. classic and current McIntosh models as well as my own power amp from 50 years ago.
